Rear suspension question
Old Nov 21, 2009 | 12:43 AM
bernie payne's Avatar
bernie payne
Default Rear suspension question
I am coming near a close with the rebuild of my rear suspension, and now I am a little bit worried on the order of what I should reconnect first. With my rebuilt trailing arms in place, what should I connect first, Strut rods, Half Shafts, Spring, or Shocks?
Old Nov 21, 2009 | 01:25 AM
another-user's Avatar
another-user
i think i worked my way from the inside, out.
bolted in the spring to the diff, put both TAs on, then half shafts, shocks, and finally struts and sway bar.
Old Nov 21, 2009 | 09:29 AM
Duke94's Avatar
Duke94
That will work just fine.
Gary
Old Nov 21, 2009 | 09:54 AM
wcsinx's Avatar
wcsinx
shock cylinder
half shaft
strut rod
brakes
spring
is the order I used
The spring will get in your way with just about everything else IMHO.
Old Nov 21, 2009 | 11:29 AM
bernie payne
Thanks guys
To Rear suspension question
