71 ls-5 heater
Old Nov 21, 2009 | 08:29 AM
roger3's Avatar
roger3
Default 71 ls-5 heater
The heater in my 71 LS-5 works a little funny. Once the car is warmed up I can turn the heater on and it blows hot air as it should. After a few minutes the temperature of the air starts cooling off until its blowing air that's pretty much the same temperature as outside. What's going on here?
Old Nov 21, 2009 | 09:19 AM
Duke94's Avatar
Duke94
Usually that means low water in the rad. But could also be a vacuum issue causing the temp valve or door to close. Does it have A/C? If so, there should be a water valve on the right inner fender well, check that the vac hose has not come loose.
Gary
