ammeter movement swap
Old Nov 23, 2009 | 11:40 AM
NMT1957's Avatar
NMT1957
Default ammeter movement swap
anybody walk me throgh a c3 ammeter movement swap.I got a new guage but the paint is bad whereas my face is good.Can i just grind off the rivets and swap the movement onto the good face? Thanks in advance for all responses.
Old Nov 23, 2009 | 12:28 PM
toddalin's Avatar
toddalin
I believe that is what my mechanic did to mine to put the original face on a new movement. Try to find "original style" rivets to redo it with.
Old Nov 23, 2009 | 04:39 PM
7T1vette's Avatar
7T1vette
Yes. If you want, you can use a 'bead' of epoxy to hold the face on instead of riveting it again. The bead can be shaped like the rivet head and then painted with semi-flat black paint...spray some paint in the cap and use a Q-tip or small brush to paint the "heads" again. Don't scar up the dial face, if you can help it; it becomes harder to match the surface well.
To ammeter movement swap
