BBC Conversion Question:
Old Jan 8, 2010 | 04:00 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Originally Posted by rbat
[/quote]
Absolutly! That would give a lot of members availability and access to the needed items.
Old Jan 8, 2010 | 04:06 PM
rbat's Avatar
rbat
Default BB conversion
I have a 75 and want to convert to a BB. It is an automatic with ac and stock l88 hood.
Can I use the same wiring harness (just replaced mine)...ac, distributor, alternator etc.
can I use the same ac lines
I am pretty sure I can use my stock hood.
what is the best way to go as for brackets and exhaust
anything else you might add would be GREATLY appreciated.
Old Jan 16, 2010 | 09:37 AM
MakoShark72's Avatar
MakoShark72
considering a 502....
Old Jan 16, 2010 | 09:22 PM
rbat's Avatar
rbat
Default 502
454, 502, 427 trying to find the right motor and combination, but I want to make sure I do my homeworke before I decide.
Any advice for a 502
Old Jan 17, 2010 | 04:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Dou you want top end power or low/mid range torque? ...and how important are its manners?
Old Jan 17, 2010 | 10:44 PM
MakoShark72
I'm not the OP, but if this keeps this thread going, I'll jump in...
In my case, I want good manners, as mine will be strictly a street car, no racing or track.
I cant see driving over 80 or so, and dont know if that means "top end", but I think low-midrange torque and acceleration would be more important to me.
I have A/C and an 2004R automatic with a 2400 converter, and plan on Hooker sidepipes. I also upgraded the suspension to VBP sport w/ front and rear sways.
I also dont want 8-10 mpg, as I have an O/D transmission and 3.08 rear end. I've read that with even a BB I could get in the mid-high teens at cruise??? Possible? Obviously, more foot, more gas..
My budget will be around $10k. I have been looking into a ZZ502.
Thanks!!
Old Jan 17, 2010 | 11:23 PM
rbat's Avatar
rbat
It will be drivin on the street only, so I want it to be a convertable reliable driver. I also am looking for it to pull through 5500-6000 with as much as can be handled down low (stock rearend and rebuilt TH400)
Old Feb 25, 2010 | 12:40 AM
mydejavooo's Avatar
mydejavooo
I have an opportunity to get 2 454's......the first is a 1985 truck 454, bored .030 over with an RV cam.........and the other is an early to mid 70's 454 from a truck with ALL accessories. Both are $500. Will they work?
PS....for those that know about my TPI swap....I am reconsidering, simply for a motor that can be installed with no wiring and such (no ECM).....still undecided.
Deja
Old Feb 25, 2010 | 12:16 PM
jnb5101's Avatar
jnb5101
i used a truck block 454 in my 72 project. the alternator was mounted on the pass side, had to get brackets and pulleys for p/s and alternator from supplier ($500 !). had the engine rebuilt as a mid range torquer for $2400. used a performerII intake and had to put a tall L88 style hood on it. it came with 3.70 gears and used a m21 trans, so it's not a top end car. but "she do light 'em up".
Old Feb 25, 2010 | 12:31 PM
markdtn's Avatar
markdtn
Deja
SB for SB is a much easier swap. The intake, hood, pullies, brackets, and exhaust manifolds or headers for a BB are quite spendy. If you want a BB that is one thing, but if you think just because you can buy a 454 core cheap that you can do it all cheap, you may want to re-evaluate. If you have any TPI questions, please PM me and I'll be happy to try to help. TPI is almost low-tech now, but I still like mine.
Old Feb 25, 2010 | 12:55 PM
Bigwheel74's Avatar
Bigwheel74
I agree, take a look at the total cost of the conversion. It is not inexpensive. Particularly the accessory brakets. Don't forget possible upgrades to the suspension, cooling, and exhaust. I enjoy my bigblock but if I had it to do over again I would go with a small block.
Old Feb 25, 2010 | 01:16 PM
mydejavooo's Avatar
mydejavooo
I see....so let me ask this......would a complete 454 with all accessories and the alternator already mounted on the driver's side, drop in and fit....I mean using the existing 454 pullies ad cast exhaust manifolds? Or will the pullies hit somewhere? And would an 85 block be a tall deck motor? I hear that there are clearance issues with a tall deck motor, but I don't know how you can tell short from tall decks.
The front suspension has to be rebuilt anyways, so the upgrade to BB springs is no biggie.
And what displacement is a 454 that has been bored .060 over
Deja
Old Feb 25, 2010 | 03:47 PM
  #33
mydejavooo's Avatar
mydejavooo
Anyone?
Old Feb 25, 2010 | 04:47 PM
  #34
rbat's Avatar
rbat
Default PLEASE create a sticky for C3 BB conversion
I am in the process of doing a BB conversion.
Concerns of a BB are
  1. the pulley system
  2. if you have a tall BB it can be done but is a bit more complicated
  3. if the BB has alum. heads, manifold and WP the weight should not be an issue for the suspension
  4. cooling is a concern for me ( I live in South Florida) but an alum. rad. will help with the weight
  5. the oil pan has to be one of the shallower ones
  6. if you go with a serpentine system the crossmember might have to be modified
  7. and of course you must have it so your tires will NOT hook (they are the fuse)up unless you upgrade the rest of the drivetain (this also applies to a built SB)
  8. if it has tall valve covers they could hit the PB booster
  9. Also I have heard the oil guage hook up is at a different location
I know these are general statements, but I have found that for every answer I get with this project it creates 2 questions. I really wish whoever has the ability to create a sticky on this great forum would do so. I have read it is a drop in project by some, but I think that term means different things gor different people AND different projects.
Deja
Old Feb 25, 2010 | 04:50 PM
  #35
MakoShark72
....I have read it is a drop in project by some, but I think that term means different things gor different people AND different projects.
And different BUDGETS...
Old Feb 25, 2010 | 05:22 PM
  #36
rbat's Avatar
rbat
the most important one
Old Feb 25, 2010 | 07:34 PM
  #37
Billysvette's Avatar
Billysvette
I think you will have to change your front springs ,do to the more weight of the bbc from sbc that has lighter springs.
To BBC Conversion Question:
Old Feb 25, 2010 | 07:43 PM
  #38
TheSkunkWorks
If the BB going in has alum heads, intake and water pump, we're actually not talking all that much more weight than an all iron SB. That said, IMHO most C3's could use stiffer front coils anyway.
Old Feb 25, 2010 | 08:17 PM
  #39
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Here is some info that may help. Vette Magazine's "Big-Block from Hell" articles make up the longest running project car series ever published by any Corvette magazine. http://www.idavette.net/hib/vette_bbfh.htm
Old Feb 25, 2010 | 11:43 PM
  #40
eagle275's Avatar
eagle275
Default .
