355 2 bolt 400hp
Old Nov 25, 2009 | 08:13 PM
Al Davis's Avatar
Al Davis
Default 355 2 bolt 400hp
I have a 79 Vette with the original 355 rebuilt engine apx 5000 miles on rebuild. Engine is built stock w/ ARP hardware. I want to ad a set of Brodix 180 with a Lunati 60103 cam 227/232 489/ 503. I am trying for 400hp. What do you think about the 2 bolt mains, would the bottom end be okay?
Old Nov 25, 2009 | 08:21 PM
Jack Wood's Avatar
Jack Wood
Default Yeah, 400 HP is a cakewalk w/two bolt mains.
Don't worry.
Old Nov 25, 2009 | 08:22 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes
Old Nov 25, 2009 | 08:30 PM
jordan89's Avatar
jordan89
You're good.
Old Nov 26, 2009 | 01:24 AM
fauxrs's Avatar
fauxrs
Not a problem in the least
Old Nov 26, 2009 | 02:08 AM
hd2002's Avatar
hd2002
Cruising
all depends on how hard you run it but driving normal you should be fine
Old Nov 26, 2009 | 07:32 AM
BLOCKMAN's Avatar
BLOCKMAN
With a 3.480 stroke your on the edge.
Old Nov 26, 2009 | 09:07 AM
7T1vette's Avatar
7T1vette
400 hp won't break the engine merely due to torque. Of course, a nearly 40 year-old engine on "steroids" can only live so long. When the load [eventually] propagates a crack, it will eventually work through to failure. More HP = less life. But, enjoy it while it 'lives'.
Old Nov 26, 2009 | 09:10 AM
scrapmaster's Avatar
scrapmaster
Don't worry, it will be fine. Built a lot of engine over the years. All of them were not 4 bolt mains. Never lost a cap or crank yet.
Old Nov 26, 2009 | 07:58 PM
BLOCKMAN's Avatar
BLOCKMAN
Most of the broken caps we have seen have been guys tring to use a 3.750 in a 2 bolt main.
In 38 years I have a 5 gallon pail with broken caps and caps that did not fit the registers because they were over powered.
http://forums.corvetteforum.com/c4-t...ps-1992-a.html
http://www.ls1tech.com/forums/advanc...ever-seen.html
Old Nov 26, 2009 | 08:06 PM
JLeatherman's Avatar
JLeatherman
Lots of guys get 400hp and more out of 2-bolt blocks for years with no problems. Of course, if there's a flaw in any of the parts eventually you'll find it, but you are by no means pushing the limits of a 2-bolt SBC.
Old Nov 27, 2009 | 08:55 AM
7T1vette's Avatar
7T1vette
A 2-bolt 350 can handle 400 hp. A 2-bolt 350 can handle 500 hp. The question is "How long can it handle XXX hp?" At any level of power an engine has a finite life; and the higher the HP the lower the life. It's that simple. I think 400 hp is about as high as you can go with a 2-bolt block and expect 'adequate' life...especially if you are going to use that 400 hp.
To 355 2 bolt 400hp
