Motor Heads - coil Qustion?
Old Nov 27, 2009 | 08:14 PM
Lt1er's Avatar
Lt1er
Default Motor Heads - coil Qustion?
I have all Crane ignition. I have to make a choice on which coil to use.
Crane makes two coils a PS92 and it's 1/2 size brother the LX92. Is a bigger coil better?
Old Nov 27, 2009 | 09:17 PM
Little Mouse's Avatar
Little Mouse
Believe the old points coils were around 20,000, the HEI came out 40,000, the new LS series engines 8 seperate coils 120,000 each coil, somebody at chevy thinks volts matter. I'm making an assumption one coil has more zap then the other or at least one handles the heat better.
Put your hand onan old factory small dia. points coil it will be very hot to the touch. One coil, one coil wire is working there hind end off trying to fire 8 cylinders. The new LS coils are barely even working at all just to fire one cylinder, what I'm getting at one place I would never try to save a dime on is the quality of a coil or the coil wire trying to keep up with 8 cylinders.
Old Nov 27, 2009 | 10:09 PM
Lt1er's Avatar
Lt1er
I'm not installing the modern 8 coil system in my old 71 vette. I'm just doing one coil and wondered if going with a modern bigger single was better than some light weight racing model.
Old Nov 27, 2009 | 10:40 PM
Little Mouse
I was just using the LS coil as an example each coil even though it puts out a lot of volts is only having to fire one cylinder making life on that coil very easy. The one coil on the older engines having to fire all eight cylinders by comparison is working itself to death, so just my opinion buy the best quality coil you can afford from a durabilty standpoint or the amount of extra volts it can also supply.
One coil having to fire eight cylinders has a very tuff job to do.
Old Nov 28, 2009 | 12:03 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A coil will only put out as much as is required to jump the plug gap. Doesn't matter if you put a coil on the size of a truck battery, it's pretty much going to only take what it needs.
The leaner the mixture, the higher the cylinder pressure etc increases needs. The individual coils work great to allow individual cylinder timing though.
But it really doesn't take anything super fancy to run well.
I can tell you my 540 runs 9's@140+ mph using a simple parts store/stock sized Bosch coil and it's been doing it for years.
JIM
Old Nov 28, 2009 | 12:17 AM
Little Mouse
Those individual coils are not working very hard compaired to one coil lol.
Old Nov 28, 2009 | 12:22 AM
Matt O's Avatar
Matt O
I thought I read somewhere the larger coils have more windings which results in a hotter spark.
Old Nov 28, 2009 | 01:15 AM
427Hotrod's Avatar
427Hotrod
Bigger coils have the *potential* to create a stronger spark if needed. If it only takes 5000 volts...that's all you're gonna get.
Top Fuelers have a monster ignition system on them and create lots of potential...sort of like a decent welder...then they tune to need that much.
Yes....multiple coils definitely have an easier life. But I can't remember the last time I ever had a bad one on a *one coil* system.
JIM
Old Nov 28, 2009 | 02:33 AM
Lt1er's Avatar
Lt1er
Well I bought the smaller lighter LX92. The directions say that it needs to be away from heat and have air flow. It also says that the aluminum heat finned mount has to be grounded. I might take it back and get the larger model
Old Nov 28, 2009 | 09:15 AM
7T1vette's Avatar
7T1vette
Take it back and get a different one...there aren't many places inside a C3 engine compartment that have "good, cool airflow". If you are still running a points type system, get the coil you want, but don't gap the plugs more than .035". If you do, the points will wear-out much sooner from the higher voltage spark. Also, find out what the supply voltage needs to be for the coil you are buying. Pre-HEI C3 ignition systems had a resistor wire built into the wiring harness which limited 'effective' power getting to the stock coil. If your new coil is for 12vdc continuous duty, you will need to run a separate 12vdc feed wire from an "Ignition" voltage source at the fuse block.
Old Nov 28, 2009 | 09:48 AM
Lt1er's Avatar
Lt1er
I'm using the crane electronic dist and H6R multispark. The Lx92 and ps 92 coils are made for cd ignitions without a ballast voltage dropping resistor.
I also run the crane 238/248 solid cam with 1.6 rockers. It purrs up to 7000 rpm, but I rarely exceed 6 or 6.5K
Old Nov 28, 2009 | 11:42 AM
Little Mouse
What if the bigger coil says the same keep it away from heat, have air flow. Anyway I was not trying to suggest anyone needs to have 120,000 ( LS engine ) volts to jump an old style narrow plug gap, or anyone should run out have to buy a CDI for there low compression street car, just another part added that could fail.
To Motor Heads - coil Qustion?
