Hurst Comp Shifter
Old Nov 28, 2009 | 11:47 AM
harrin's Avatar
harrin
Default Hurst Comp Shifter
Hi Guys,
I'm about to get rid of the stock shifter (sloppy) and replace it with the hurst. I noticed there is a spacer and stiffner in the package, but not on the instruction sheet, do I need these?
Any advice or pics would be greatly appreceated.
BTW - BB with M21
Rick
Old Nov 28, 2009 | 01:22 PM
69 Chevy's Avatar
69 Chevy
Both are listed on my circa '69 instruction sheet. I installed both the spacer and the stiffener on my M21 mouse motor in the early '70's, cause it has a console. It has been shifting quite well all these years. And I just checked, they're both still in place!
Old Nov 28, 2009 | 01:45 PM
Duke94's Avatar
Duke94
The instruction sheet that came with mine (about 6 years ago) shows the spacer. Don't recall if I used it or not. You'll know when you get the shifter mounted up weather you need it or not. If the shift handle isn't centered in the console, you may need the spacer.
Gary
Old Nov 28, 2009 | 01:51 PM
another-user's Avatar
another-user
anyone know what the dimensions are on that spacer? i bought a used shifter and it didnt come with one, so i need to make one. ive been running with out a shift plate for about 3 years now and im kinda getting sick of it.
Old Nov 28, 2009 | 03:05 PM
Big Block 69's Avatar
Big Block 69
As I recall, The spacer is about the same thickness as the Shifter Handle. You could trace the bottom of the stick onto another piece of metal, then cut it out.
Old Nov 28, 2009 | 03:11 PM
another-user
ya, thats kind of what i was planning on doing. just didnt know the width of of.
Old Nov 28, 2009 | 03:29 PM
Duke94's Avatar
Duke94
You can buy it from Summit for about 7 bucks.
Gary
http://www.summitracing.com/search/?...228-8397&dds=1
Old Nov 28, 2009 | 07:33 PM
71coupe454's Avatar
71coupe454
I believe mine had one and I used it..
Old Nov 29, 2009 | 10:11 PM
L79racer's Avatar
L79racer
You might need it when you try and put it in reverse when using a console.
To Hurst Comp Shifter
