engine suggestions/ turn key or not?
I just noticed that Jeg's has the ZZ4 turn key for $4919 - about $80 less than the HO and $1200 less than the Fast Burn 385.
I just started a project with a friend, with a 69 Camaro
IF you have taken a motor apart and got it back together correctly in the past,
Then you can pick and choose your individual componets,
to acheive your desired performance level.
with previous experinece you should have enough knowledge to select the proper componets. remember an Engine is the sum of how well all componets are selected,
with a turn-key somone already has made those desicions for you.
Not all local Engine builders would get my recomendation.
But thats a whole new challange finding a competent Engine machine shop.
69VETT
I recently went through this process myself, while installing a zz383 engine, and my mechanical skills are minimal.
GM crate engines can be really easy to match parts for, as the GM engine manual provides details and part numbers for most of the parts required to complete the engine.
ZZ383:
http://www.gmperformanceparts.com/_r...sp88962517.pdf
Fast Burn 385:
http://www.gmperformanceparts.com/_r...5_Turn_Key.pdf
Depending on which engine you select, many of the parts choices will be automatic.
For example, both of these engines will require Vortec intake manifold, D-port exhaust headers, square-bore carburettor, HEI distributor (possibly with mechanical tach drive, depending on your car's year), a Corvette style water pump compatible with the composite timing chain cover, etc.
From there it just comes down to budget and personal brand preference. Issues like hood, exhaust & engine bay clearance and wether you want to reuse some of your old parts (pulleys, brackets etc.) will also dictate some of your part choices.
There is a wealth of information regarding parts combinations and installation of either of these engines contained both within this forum and elsewhere on the net.
Don't wander into the first one you come across, do some research:
- Local tracks
- Local Saturday cruises
- Local car clubs
- Ask the guy at the traffic light who build his motor
- Ask your neighbor, or the guy down the street
GM Performance Parts p/n 12499101
GM Performance Parts HT 383 CID
340HP/435TRQ
Only crates I'd suggest are NEW genuine GM. Otherwise, build motor yourself or have a local shop build motor.
If you give your general location members might be able to make recommendations of shops in your area.
