DIY Cold Air Intake
Back of the L-88 hood opened up to a 3" tall opening for air flow.
1 layer of fiberglass and poyester resin applied to the top of a sheet of cardboard , resin and fiberglass from Home Depot. Base plate from 9" air cleaner glassed to bottom.
Clearance to hood checked with modeling clay.
Cardboard cut for sides.
One layer of glass applied to inside of side walls. Tape removed and outside glassed.
About a half a tube of glazing putty used to smooth eveything up.
Round pipe insulation used to seal CAI to hood.
I was going to paint it completely black but a buddy suggested I use red. I went half and half.
Some shots of the finished project.
I ordered a larger air cleaner with a flow through lid and chrome accents. Should look better.
Maybe a "CHEVROLET" script decal on both sides or maybe just one around the front edge would add a little "finishing" touch. Let me know and I will cut them for you.
Nick
I did up a cardboard template to do something similar on my '64 with a '67 BB hood and an opened front scoop, but never followed through with the fiberglassing. My hat's off to you!
My only problem with doing such a thing is that you really cover the view of the engine, which may be a good or bad thing.
I am not too proud to copy or listen to a good idea!
I think 45 degree angle cuts to make the round seals match and generate a 90 degree angle would look a lot better. Unfortunately the underside of the hood has a step and the seals have to match. I am still up for suggestions...
Nick,
I will take you up in your Corvette script offer. I’ll send you a PM.
I’m looking forward to seeing if the track time improves. It’s counter intuitive that a reverse facing scoop will force air into the carb but I have a buddy with a 66 Chevy II and his reverse facing scoop took .2 sec off his 1/4 mile time.
I was doing this mostly for function. It's easy to remove and I was planning to take it off for car shows. Since I followed my buddy's suggestion of painting it red, it looks better than I hoped. Now with some Corvette scripts......
I worked on this project off and on for at least 3 days and several 6 packs. I had to wait for the resin and glazing putty to cure between applications, good time to put up the tools and drink beer. I do like working with fiberglass and resin. I don’t like sanding but it’s better than cooking and cleaning.
I really like the L-88 hood but I bought it from a company in Canada and had to rework it big time to make it fit. There may be other suppliers of L-88 hoods that fit better.
Redman,
Give it a try. Cost is ~ $20 in materials. Take your time and I'm sure you will be sucessful.
Thanks for posting!
JIM
