Bleeding brakes
Old Nov 30, 2009 | 03:57 PM
marz's Avatar
marz
Default Bleeding brakes
I have to say that after bleeding brakes the old fashioned way ( wife pumping the brakes) I finally decided to try the speed bleeders from Jeg's. Five minutes to change them out and another five minutes to pump them and I have the most brakes I have ever had on the car.
Anyway...FYI...if you are having trouble bleeding your brakes. I should have done this long ago.
Old Nov 30, 2009 | 04:32 PM
midyearvette's Avatar
midyearvette
yep!!..but you wont change anybody else from using their vacuum or pressure bleeders......i gave all my bleeding contraptions away after i tried the speed bleeders....
Old Nov 30, 2009 | 04:37 PM
marz's Avatar
marz
This one is converted for life!
Old Dec 21, 2009 | 03:36 AM
2006c6keller's Avatar
2006c6keller
Default Speed bleeders part number and maker?
Do you have the speed bleeder part # and maker for a 2006 c6 F55. Thanks!
Old Dec 21, 2009 | 07:08 AM
marz's Avatar
marz
Russell Speed Bleeder part # 639560 for front and back.
Old Dec 21, 2009 | 02:37 PM
GPGG70's Avatar
GPGG70
I'm not up to date with the speed bleeders. What do they do different then the old type?
Thanks.
Old Dec 21, 2009 | 02:43 PM
midyearvette
Thanks.
simple..you just crack them open one at a time..pump the pedal a few times and tighten them back up..of course checking m/c levels as you go....nutttin to it.......they are equipped with a one way check valve....
Old Dec 21, 2009 | 03:04 PM
Vette79C3's Avatar
Vette79C3
Motive Power Bleeder works great!
http://www.motiveproducts.com/
Old Dec 21, 2009 | 03:44 PM
midyearvette
to each his own....speed bleeders are a heck of a lot easier and a lot less cumbersome, without the tank, hoses, building pressure etc.......jmo..good luck
Old Dec 21, 2009 | 06:30 PM
marz's Avatar
marz
Amen to that! Easiest bleed job I have ever done. Try them out. You will never go back. Some guys like to go the other route, but don't know why. JMO.
Thanks. Hope this helps.
Old Dec 21, 2009 | 08:03 PM
Project80's Avatar
Project80
Speed bleeders work well for me but I use the power unit to flush the lines (until clear fluid runs). When replacing a master, you still need to bench bleed the unit.
Old Dec 22, 2009 | 12:26 PM
GPGG70's Avatar
GPGG70
Thanks for the information guy's you all sold me. I'll try them.
Old Dec 22, 2009 | 01:02 PM
midyearvette
hey gpgg.....be sure to suck out the old fluid from the master first and fill with fresh....then pump till you see clean fluid, check the master after each bleeder and you are good to go..btw..4 bleeders on the rear!!
Old Dec 22, 2009 | 02:04 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you have replaced all your lines and put on new calipers, you need some kind of vacuum or pressure on one end or the other to get the fluid going. I use a hand held vacuum pump it has never failed in this situation.
If I am bleeding an existing system after changing pad or a soft pedal or whatever I use a clear plastic hose and a beer bottle works perfect every time
Old Dec 22, 2009 | 11:06 PM
GPGG70's Avatar
GPGG70
Thanks againg for all the information Mr marz, midyearvette & motorhead.
Make a long story as short as I can I'm going to have to change out most of my brake system by my choice due to the master cylinder shooting craps on me last week. I had just finished flushing new fluid thru everything and like MH said I used the hose/plastic bottle trick while I did the gravity bleed. Three days later I found the leak at the M/C.
Ok the M/C should show up tomorrow but will be lucky to get started on the M/C install after the first of the year.
I'm also installing new SS hoses, fluid, rotors, pads, & calipers which brings me to the Speed bleeders.
Will a quarter of a turn get them to start working or a couple of full turns to start bleeding & I'll have my hand vac pump standing by to start the bleed after the M/C has been installed. Is it best to use a thread sealer on the bleeder threads?
So other then keeping the reservior full of fluid all I have to do is pump the brakes?
Is the brake pumping with the engine running or not cause I have PB.
I sure hope you dont feel like I'm taking over this thread and if so I'll be glad to start a new one, but I'm looking forward to doing this job believe it or not.
Have I missed any thing else about the bleeders?
Old Dec 23, 2009 | 08:07 AM
marz's Avatar
marz
Quarter turn is all it needs. I did mine with the motor running to make sure it had plenty of pressure. Pump it to the floor, hold and pump once more. Close it back up and go with the next one.
Old Dec 23, 2009 | 10:28 AM
GPGG70's Avatar
GPGG70
All right, that's great and thank you for the information.
To Bleeding brakes
Old Dec 23, 2009 | 02:34 PM
dariopop's Avatar
dariopop
I have 5 vehicles so I use a Motive Pressure Bleeder and change out my fluid every 3 years and it works great , I purchased the speed bleeders for the Vette as I tend to work on it more than the other cars and the speed bleeders work great for after repairing one caliper or so.
But for total flush I use my Motive pressure bleeder , it takes a lot of getting into and out of the car and refilling the brake reservoir to run a quart of fresh brake fluid thru the system for a total flush.
Old Dec 23, 2009 | 06:13 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
I was going to order a Motive bleeder, but after reading this thread I think I just need speed bleeders! Sounds easy.
Old Dec 23, 2009 | 06:22 PM
jbaron's Avatar
jbaron
BTW, I need 6 bleeders,correct? (2 ea. rear)
