headers
Old Nov 30, 2009 | 11:49 PM
Cuervos77's Avatar
Cuervos77
Default headers
can i replace the headers on my car without pulling the engine is there anyone other way ?
Old Nov 30, 2009 | 11:52 PM
FlyViper's Avatar
FlyViper
Yes. Depending on whether your headers are bolted to the x/h-pipe or welded will determine how easy that part is. Once you unbolt them from the heads and unbolt/un-weld from the x/h-pipe, you'll be able to finagle them out of there from underneath the car. You'll have to disconnect your spark plug wires and maybe your Z-bar, but other than those, you shouldn't have to remove anything else.
Old Dec 1, 2009 | 12:08 AM
Cuervos77's Avatar
Cuervos77
thanks alot i bought some from summit pretty good deal on some hookers so you just save my life
Old Dec 1, 2009 | 02:27 AM
rexx78's Avatar
rexx78
I put my headers in but had to remove the starter and z-bar on my 4 speed. I don't remember, but I may have had to lift the rear of the engine with a jack too. It can be done though.
Old Dec 1, 2009 | 03:53 AM
RunningMan373's Avatar
RunningMan373
I just installed a set also. i only had to remove the Z-bar for the 4-speed, starter stayed in. You will need to jack the car up, and install them from below though. Went in in like 1 hour.
To headers
