TCC Test point? What?
Old Dec 1, 2009 | 12:26 AM
dburgjohn's Avatar
dburgjohn
Default TCC Test point? What?
The dealer service manual makes reference to 'TCC test point in fuse block' on page 7A-16. Can anyone shed some light on which terminal that is?
Old Dec 1, 2009 | 10:45 PM
dburgjohn's Avatar
dburgjohn
what no GM guys out there to help?
Old Dec 2, 2009 | 08:44 AM
...Roger...'s Avatar
...Roger...
I looked at your post yesterday and got my 81 book out but couldn't find a TCC test point "in" the fuse box described in the manual.
When it comes to anything that ties in with Computer Command Control things start to get hazy when your using the GM manual.
I'm not sure what your looking for but the first part of the test on 7A-16 seems to be testing the brake switch. The test in this section seems a bit generic for GM models. Would the test on 6E1-33 and 6E1-34 cover what your looking for ?
I think testing these systems when the manual was written were too complicated and confusing for most of us to understand. I believe there are easier test procedures and better explained ones to be found.
Old Dec 2, 2009 | 03:32 PM
dburgjohn's Avatar
dburgjohn
Default Best guess
I am thinking there must be a terminal or fuse in the block, but the diagrams of the fuse block in the Service Manual and Owners manual don't mention TCC.
How did the mechanics know in 1981?
Old Dec 2, 2009 | 04:21 PM
...Roger...
I'm pretty sure but not 100% that it should have read from "TCC test point in ALDL to ground".
Old Dec 2, 2009 | 11:35 PM
dburgjohn's Avatar
dburgjohn
The terminal under the console? thought about that but the wording uses fuse block
Old Dec 3, 2009 | 07:52 AM
hugie82's Avatar
hugie82
I read in one of the camaro web sites that they were using a jumper wire on the ECM plug for the lock up function but I forgot which terminals.
Old Dec 3, 2009 | 09:31 AM
...Roger...
Yes. The other tests in the book use the ALDL as the test point.
Where are the guys that are familiar with testing in the 81 , I have done very little testing in the trans area. Sixfooter where are you ?
Old Dec 4, 2009 | 01:07 PM
SSG26K's Avatar
SSG26K
Terminal 'F' on the ALDL is your TCC test point.(Tan/Black wire) If you ground it your TCC should engage.
Old Dec 4, 2009 | 05:38 PM
dburgjohn's Avatar
dburgjohn
I am looking at the other side starting with 12v not the ground, but thanks, that will be needed too
To TCC Test point? What?
