Temp gauge schematic?
Old Dec 2, 2009 | 10:08 AM
jim2527's Avatar
jim2527
Default Temp gauge schematic?
For some odd unknown reason I disassembled the back of my temp gauge to clean up the brass. Apparently I mis-assembled it because it's no longer accurate. It goes up to about 155 and stops. I think one of the small washers may be in the wrong postion.
Anyone have a schematic of the proper position of all those little pieces or perhaps a hi-res pic of the backside of the temp gauge?
Its a '70. I did check all the available publications...
Thanks,
Jim
Old Dec 2, 2009 | 10:14 AM
Apocolips's Avatar
Apocolips
Thanks,
Jim
I have the same problem. I didn't disassemble the gauge, but my 1970 350/300 always indicates 155. I have an infrared temp gun and it indicates temp to be right at 180. I don'twant to buy a new gauge but I would really like the gauge to read correct temp.
Old Dec 2, 2009 | 02:58 PM
...Roger...'s Avatar
...Roger...
If this doesn't do it for you I can tell you per stud the correct items and order they are installed.
http://willcoxcorvette.com/instructi...ions_68-82.jpg
Old Dec 2, 2009 | 10:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I've seen that pic before..
Old Dec 3, 2009 | 08:23 AM
jim2527's Avatar
jim2527
Thanks!!! I'll take a look later today and report back.
Jim
Old Dec 3, 2009 | 04:49 PM
jim2527's Avatar
jim2527
It appears to be assembled correctly. I dont know what to check now, it was working fine before I took it apart.
Old Dec 3, 2009 | 05:14 PM
...Roger...
Whats the ohms reading across term 9 and 3 oclock. Should read about 45 ohms if I remember right.
edit - hold the phone-45 is from the 12 to 6
9 to 3 is around 80 ohms
Old Dec 3, 2009 | 06:24 PM
jim2527's Avatar
jim2527
It's close. With it assembled properly and the 3-prong connector removed I have:
49 ohms across 12 to 6 and
88 ohms across 9 to 3.
Old Dec 3, 2009 | 07:04 PM
...Roger...
You should be good with those readings. Have you done the unground and ground of the sender wire test ?
Old Dec 3, 2009 | 07:18 PM
...Roger...
If you have some resistors laying around you can bench test the gauge. A 2 pack at Radio Shack is about $1. If you don't have any resistors laying around you can substitute your turn signal or hazard flasher after you read its resistance.
Old Dec 3, 2009 | 07:38 PM
0Willcox Corvette
Former Vendor
Jim,
If you have around 90 ohms resistor and the gauge is installed properly in the cluster housing, I would do this:
Plug up the connector.
Attach the ground wire to the cluster.
With the key on remove the sending unit wire, the gauge should go to cold.
With the key on ground out the sending unit wire and the gauge should peg.
A sign of a resistor problem is a terribly low reading on the gauge but if you tested it then this rules out the resistor unless for some reason contact is not being made to the stud. I would remove the nuts and connectors and clean the contact points between the housing, stud and resistor and and test again.
If you do this function test on the gauge and it works great, but if it fails then run an independent ground from the car to the center dash cluster and test again.
All else fails, pull the gauge out send it to me and I'll test it for you... Christmas present!
I can eliminate or nail the gauge as the problem in about two minutes.
Willcox
Old Dec 3, 2009 | 08:37 PM
jim2527's Avatar
jim2527
If your referring to the test outlined by Wilcox below then no, I haven't.
Originally Posted by Willcox Corvette
Jim,
With the key on ground out the sending unit wire and the gauge should peg. :
Is there any place in particular I sould be ground the cluster? I'm assuming I can use a piece of wire with alligator clips.
Thanks,
Jim
Old Dec 3, 2009 | 10:27 PM
0Willcox Corvette
Former Vendor
Yes that is what Roger is talking about.
Thanks,
Jim
Anywhere on the back metal can that the gauges bolt to and you'll be fine.
Willcox
Old Dec 4, 2009 | 08:00 AM
...Roger...
Jim if all you did was disassemble and clean ( and didn't do anything under the hood ) then it would make sense the problem is at the gauge. You said you cleaned the "brass" and I'm guessing thats the studs on the gauge but the more important connections are the 3 spade connections including the connectors in the harness. A high gauge reading of 155 would indicate a dirty or poor connection on the upper spade (the one connected to the 12 oclock stud).
The standard gauge initial test we are speaking of is easy and quick to do.
Reattach the 3 wire connector on the back of the gauge (black wire in connector should ground cluster)
turn ign key to on
under the hood remove the green sender wire -- temp gauge should go to cold
now ground the sender wire-- temp gauge should go to hot
If on this last step the gauge only goes to 155 then we will have to move on to some bench testing or send the gauge to Ernie. (It is possible the needle slipped.)
Ernie I thought you had a complete test on your site for the temp gauge,I can't find it so I can link it. I need to copy all these links and put them in some kind of order.
Old Dec 4, 2009 | 09:29 AM
7T1vette's Avatar
7T1vette
If the gauge works, it isn't the gauge. Did you replace the temp sensor at the same time? If so, your temp sensor may not be correct for your year car. Some of the aftermarket stuff is 'generic' and doesn't provide correct readings. Do the testing Willcox suggested. If that works OK, your gauge, resistor, and wiring are OK. The only item left is the sensor.
P.S. Any possibility that the engine is operating at 160 F? Low temp T-stat or old stat stuck open?
Old Dec 4, 2009 | 08:18 PM
0Willcox Corvette
Former Vendor
turn ign key to on
Roger, I had a video on youtube but removed it the other day. It just needed to be done better. I'm a little more advance on this video stuff and I'm almost done with a new one for the tach's too! Maybe this winter I'll get some more of them done for you guys.
Roger, you can search these by entering the year and selecting "Help and Repair" from the center drop down box. Then narrow the search with a one word search such as "temp" or "fuel".
One thing that concerned me in this picture was the amount of corrosion on the terminal in the picture. The studs look great, but the corrosion should be removed from all the terminals top and bottom side.
Willcox
Old Dec 4, 2009 | 08:37 PM
jim2527's Avatar
jim2527
I did the sensor awhile back and used the approriate part from lectriclimited. I'm in Tampa, there's no way my cars running at 160. I'm going run the tests in the morning, I'll report back with the results.
Jim
Old Dec 6, 2009 | 02:48 PM
jim2527's Avatar
jim2527
I did the tests and the gauge seems to be OK. It is possible the engines only getting to 160 but I was having this problem in the dead of summer in Tampas heat and humidity.
I checked various under hood temps with my IR temp gun, some, like the lower radiator hose were very low (125) while the upper hose and thermostat housing where in the 165 range. I let it idle for 15 minutes which should be plenty long enough to get it up to normal temps and the gauge barely moved past baseline. Even after turning it off and letting the engine heat sink it still didnt move much.
The sending unit is proper for my car, its only 2 years old but I suppose it could be bad.
Jim
Old Dec 6, 2009 | 02:57 PM
...Roger...
Here is a simple test ( i didnt say I was simple) using what you have at home. Attach the green temp sender wire to your hazard flasher and touch the other terminal of the flasher to ground and see what your gauge reads. Then remove the flasher and measure the ohms between the 2 terminals and compare that to the temp gauge ohm chart on Willcox's site. That should tell us if your gauge is accurate.
From Willcox site :
220 degrees = 70 ohms
200 degrees = 90 ohms
160 degrees = 140 ohms
120 degrees = 250 ohms
100 degrees = 340 ohms
To Temp gauge schematic?
