lets see your stance...
Old Dec 5, 2009 | 09:32 AM
  #41
LFZ's Avatar
LFZ
George...you holdin' out on us???
Old Dec 5, 2009 | 10:07 AM
  #42
Paul L's Avatar
Paul L
OK, here's pretty much stock. Those are 235/60R-15 tires. The original OEM 6" spring bolts in back with OEM rubber cushings.
Old Dec 5, 2009 | 10:56 AM
  #43
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Fronts: 9.5x17 with 295-35-17's
Rears: 11x17 with 315-35-17's
Old Dec 5, 2009 | 11:05 AM
  #44
Garys 68's Avatar
Garys 68
68 on original 7" rims. 225 70 15". 10" bolts rear. Front springs were cut before I got the car. I added Vintage Air, a much larger radiator, and a heavier Richmond 6 speed trans. I had it aligned and there's only 1 shim on the fronts. You cant go any lower without drop spindles.
Old Dec 5, 2009 | 11:31 AM
  #45
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Here's mine
Right after pulling it back into the street from rebuilding the suspension. Rear has settled a bit since then:
Here's the original look:
Still looking for recent shots with the new chrome ralleys on it. It has 550 springs up front, half coil cut off. Rears have 8" bolts. The whole car now is 1 1/2" lower than the original picture, above
Old Dec 5, 2009 | 11:32 AM
  #46
Lt1er's Avatar
Lt1er
NM, That is way to nice for a road racing car! What are you running for brakes and springs. What class is 3mb?
Old Dec 5, 2009 | 11:39 AM
  #47
SanDiegoPaul
Here's the rest of the shots I was looking for!!
New Wheels and suspension settled:
Coys Wheel
Interior shot for fun
Old Dec 5, 2009 | 12:03 PM
  #48
luerja's Avatar
luerja
Front 18 x 9.5 with 275/35-18
Rear 18 x 12.5 with 335/30-18, double offset trailing arms
4.5 backspace and 1.5" adapters on all wheels.
Old Dec 5, 2009 | 01:22 PM
  #49
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Dec 5, 2009 | 01:42 PM
  #50
NMsharkracer
Stock brakes with a hydroboost. 1000# Guldstand coils in the front, 460# mono in the rear. 3MB is an NCCC modified class.
Old Dec 5, 2009 | 03:54 PM
  #51
zigvs's Avatar
zigvs
what fender flares are you using?Love the nostalgia numbers
Old Dec 5, 2009 | 05:05 PM
  #52
Highhat's Avatar
Highhat
Weld Draglite rims
26 x 4 front (MT Sportsman Fronts 26 x 7.50-10) with Moroso Trick Springs, and 1.5 coil cut
275/60-15 (15 x 8 x 28") MT Drag Radials with 5 leaf steel spring and QA1 shocks
Old Dec 6, 2009 | 02:44 AM
  #53
Peterbuilt's Avatar
Peterbuilt
Default Then and now!
Purchased my 74 used in 77, ground up restoration in 2001. New stock GM motor, rebuilt TH400, Western 10 X 15 rims. I think that over the 30 years the Vette has aged better than I have.
Old Dec 6, 2009 | 02:51 AM
  #54
Peterbuilt's Avatar
Peterbuilt
Default This year.
More recent picture.
Old Dec 6, 2009 | 09:18 AM
  #55
jb78L-82's Avatar
jb78L-82
Can someone explain how to send a picture to a thread on the forum from my pictures on my computer? A little slow here but just want to post a picture to this thread. Very frustrating!
Old Dec 6, 2009 | 09:49 AM
  #56
redwingvette's Avatar
redwingvette
Open a Photobucket account and upload pictures there. Then you can use it to show the pictures here.
235/60-15 on stock rims. TRW fiberglass rear spring, stock front springs.
Old Dec 6, 2009 | 10:03 AM
  #57
NMsharkracer
Thanks...flares were from Vanacour in Louisiana. I believe they called them ZL1 flares.
To lets see your stance...
Old Dec 6, 2009 | 11:05 AM
  #58
Blackkaz04's Avatar
Blackkaz04
Petes74...I want to see the after picture of you!
Old Dec 6, 2009 | 11:23 AM
  #59
jb78L-82's Avatar
jb78L-82
Thanx so much
Old Dec 6, 2009 | 11:26 AM
  #60
jb78L-82's Avatar
jb78L-82
[IMG][/IMG]
Kuhmo 255/45/17 ZR Front 255/50/17 ZR's rear 550lb Front Coils 1 inch lower than Stock, 360lb Fiberglass Rear Spring
