Summit Distributor Mounting info.....
Old Dec 3, 2009 | 10:17 PM
WhiteC3's Avatar
WhiteC3
Default Summit Distributor Mounting info.....
I have a 81 I just decomputerized. Sorry...it's the best thing I ever did to this car. It runs the best it ever has! I installed a new Summit blue printed distributor. I noticed at start-up the oil pressure was bouncing some but seemed to go away when warmed up.Then after a drive I noticed some oil around dist. I grabbed the dist. and wiggled it and it slipped. So I tried to tighten it it was fully tight. So meanwhile I bought 5 original GM HEI distributors off ebay for a great price. Removed the summit unit and measured clamping ring on base and it is conciderably thinner than oem part. Well that explains why it won't clamp tight. I also noticed how cheap and flimsy the mech advance is on the summit dist.and the drive gear has thinner teeth. So I plan on building my own oem dist. up with new electronics.So much for a new distributor!
