Need help with Cost Estimate Exterior Work
I know I need a new big block hood (about 1k), new front grill trim, one side sill (drivers side). I know I need to remove the passengers side mirror, and probably get a new drivers side as it doesn't look original. I will remove the rear rack and fill those holes. I need two rally caps, and need to repaint the wheels back to silver. I could figure the cost on this stuff. But it does look that the car had a minor hit to the driver side front as the chrome is a little off and the hood doesn't quite fit right. The car is originally riverside gold. I will not be doing any body work or paint myself (besides easy work like removal of chrome, sills, painting the wheels, changing the incorrect antenna).
What do you guys think, if anyone can help out with guesstimates on cost and brake it out, (for example prep work, paint, parts).
The car is an L68 and the engine and trans are supposed to be correct and not restamped. The price is low but will only be good if repair costs are not extravagant.
Thanks in advance.
. Yes, that much; they are pretty hard to come by. [That's why they're missing now.] The rocker panels are wrong and are about $300 to replace, The hood doesn't fit too well; if you pay $1000 for a 'real' BB hood...in good condition...it can be made to fit much better. If you buy a reman hood, it won't fit well without lots of work.Now, that hasn't even addressed the mechanical aspect of that car. With a car that "rough" on the outside, what's the chance that the mechanicals are in good shape? Nearly ZERO, I would imagine. How's the interior? How's the frame for rust?
IF the frame/birdcage are not rusted out...and IF the mechanical stuff [engine, tranny, brakes, suspension, steering, engine accessories] are all functional and seem OK...and IF the interior doesn't have to be replaced...and IF you can do the body and paint work, that car may be worth $3000. Is that what you were asking?
Yes it will cost $10K -12K to fix and paint.
The interior is actually not as bad as the exterior, there are some things wrong (like the radio is not correct). There is no rust as it is a black plate california car. In addition to that it has Power Brakes, Windows and Tilt Column. It also has A/C and TI. It is a very well optioned car.
Supposedly the engine "runs strong". The car is only 1.5 hours from me and I can go see it Tomorrow.
Thanks again.
I really appreciate the forum's help.
If it doesn't have any serious rust issues go for it if the price is right in your mind.
