removing the body from the frame.
Old Dec 4, 2009 | 04:27 PM
twoironnutz's Avatar
twoironnutz
Default removing the body from the frame.
i have a 75' vette and it's been sitting outside my house for about 13 years...finally my dad let me have it so im thinking about lifting up the body from the frame and sand blasting the frame to take out the rust. I know that i have to remove the body mounts ( most likely gonna brake them) and taking off the linkage for the brakes and steering. Is there anything else im missing before i attempt to do this?
Old Dec 4, 2009 | 04:38 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Yes a boat load of stuff !
Bumpers and mounts, wiring, battery cables, Gnd cables, parking brake cable, driveshaft safety loop. speed O-cables, tach cable
a ton of stuff under the hood; steering linkage, Hoses, brakes lines,
clutch linkages, wiring, accelrator cable
rear vallance, Radiator and support mounts,
you need to do a lot of research. 69VETT
Old Dec 4, 2009 | 05:39 PM
Tom's 79's Avatar
Tom's 79
I have a body removal checklist. It is 13 pages I can email you a copy if you want. I got it from someone who posted it on this forum. Let me know your email address if you want a copy.
Old Dec 4, 2009 | 05:49 PM
twoironnutz
It would help alot if i had a check list. I'm new to all this and i want to thank you guys for the help
Old Dec 4, 2009 | 06:25 PM
cargo247's Avatar
cargo247
Tom could i get a copy of that check list i will pm my email address.
Todd
Old Dec 4, 2009 | 06:31 PM
Tom's 79's Avatar
Tom's 79
Cargo, (and anyone else), absolutely.
Iron, don't forget to send me your email address.
Old Dec 4, 2009 | 09:50 PM
20mercury's Avatar
20mercury
Default I would like a copy of the check list too.
I would like a copy of the check list too. Maybe just post it here, good info. Thanks.
Old Dec 4, 2009 | 10:21 PM
Tom's 79's Avatar
Tom's 79
It's 13 pages and in a pdf file. If you can tell me how to do it I'll post it...
Old Dec 4, 2009 | 10:45 PM
redwingvette's Avatar
redwingvette
Here is my page on what I did to lift my 73 coupe:
Body-off project
Old Feb 3, 2010 | 09:04 PM
airtime's Avatar
airtime
geraldhocutt@hotmail.com could you email me your list. thanks i just got done with the front suspension, motor and trans. rear suspension and frame maybe next.
Old Feb 3, 2010 | 10:10 PM
67tripwr's Avatar
67tripwr
Be sure to notate shim locations, and the amount of shims at each one.
Old Feb 3, 2010 | 10:38 PM
skaping's Avatar
skaping
Take your time. Once you get everything undone jack it up an inch or so at a time and check all around before proceeding in case you miss something! Sometimes the shims stick to the body so be sure to get all of them and make a diagram of how many went where so you can get it back together without messing up the body. Do not use an impact on the body mount bolts as you can stretch out the little "cage" that holds the square nuts and then the nuts will spin. I learned that one the hard way!
Good luck!
Old Feb 4, 2010 | 04:29 PM
Alan 71's Avatar
Alan 71
I missed the ground wire on the starter. It made the cutest little 'ping' when the wire popped.
Regards,
Alan
Old Feb 4, 2010 | 06:18 PM
Pacha's Avatar
Pacha
Regards,
Alan
I gorgot to disconect parking brake cable and almost lift body and frame altogether, I broke the rear splashguards by doing that
Old Feb 4, 2010 | 07:05 PM
zigvs's Avatar
zigvs
I forgot the antenna ground and then the bolt dead center of the nose.
Old Feb 4, 2010 | 08:08 PM
la80vette's Avatar
la80vette
Don't say you're gonna break the body mount bolts. If you break, them you'll say you shoudn't have said that. Instead start spraying them now with penetrating fluid. By the time you get everything on the checklist done they will be lubricated and ready to come out. I didn't break one and they came out nice and easy. I did break the trans kickdown cable when lifting the body though. It got hung up on something. Just go slow and have someone check around the car as you inch the body up.
God bless
Stephen
To removing the body from the frame.
