engine won't fire...think I checked everything
I had a TPI set up on this car about a year ago and one day while trying to datalog it died on me and I could never get it to start. It was like it wasn't getting any gas....it would turn over but it wouldn't fire.
I checked all the normal stuff, timing, spark, fuel..etc everything looked good.
1. I had spark at the coil and the cylinders (new wires and plugs)
2. Fuel pressure was fine
3. I re-timed it several times according to the TPI camaro manual and info from this site, pulled #1 plug and had my wife bump the starter with my thumb on the hole until I got a "woosh" of air from the cylinder.
I manually turned the engine a short turn to TDC (it was almost there) and pointed the distributor rotor towards the #1 plug and tried to fire the engine again.
No luck
I then pulled all the TPI stuff back off and sold it because I was so aggravated. I never could get it to run right since I put it on anyways.
So I installed a carb intake back on the engine along with a fairly new Holley street avenger 570 carb. I also put a mech fuel pump back on the block and tightened everything down. I also put on a new vacuum advanced distributor.
I then re-set the timing like described above.....same problems, turns over but won't fire.
So my question is: What could be wrong here? I had to set my valve lash when I installed the heads, could it be possible that they are too tight causing the exhaust to dump at the wrong time? I used Lars tech paper, but I'm paranoid and could have overtightened a little or did this wrong....but it ran fine for a little while, heck I even drove to a show in town.
Could improper valve adjustment cause an engine not to start? This is the only thing I can think of but am open to any suggestions.
This would be fairly obvious though as the engine would spin over much quicker than normal.
What colour is the spark at the plug, is it yellow or bright blue?
Also, as a quick check of valve lash, typically there should be 4 threads showing above the adjusting nut on a stock SB.
Gary
Is there power to the coil, and have you verified spark? Engine TDC on Compression Stroke, is the ign rotor pointing to #1 on the cap?
I think my battery is toast, it's been on the charger for a while and it's only good for about 10-15 revolutions and it dies as quick as it starts.
I also noticed I wasn't getting any fuel up to the carburator, maybe it's because the car has cycled the mech pump enough to get a good prime.
I really think my timing skills suck.....I pulled a msd ignition set-up off the 350 my 76 Camaro to trade, I didn't want to pull the distributor but the guy wanted it. I installed a new HEI unit in it and can't get it to start either. I thought if I put the distributor in the same spot as the old one and it would be ok. Car ran fine until I messed with it.
I'm going back and forth right now between both cars......I just wanted to get them running long enough to put the camaro in my shop for winter work and put the vette under my carport.
Now I'm timing this correctly I hope...I pull the #1 plug and put my finger over the hole....as it's coming to the compression stroke I get a woosh of air, then move the harmonic balancer grooved line to match up with the timing tab 0 mark. Then I should be able adjust the distributor from there for factory settings.
Anyone have any good step by step pics to show me how the rotor should be pointing towards the #1 plug and the orientation of the wires for firening order. All I have found are drawings online and nothing of the actual HEI stuff.
This is the reference I am using
When I spray starting fluid in the carb it runs for a quick second....I mean you count to 1 and that's how long it tries to run.
I even changed the fuel delivery from electrical to mechanical, carburetor, and new distributor....still no dice.
My wife will be home in a bit so she can help me crank the car while I check timing again. I'll take pics of what I have and the positions of the rotor so everything can be verified.
When cranking the engine I have my wife bump the starter until I feel the rush of air in the #1 then we stop the engine at that moment. I then rotate the crank clockwise to get to TDC mark on the harmonic balancer...it's not far off from there.
Once i have the HB mark lined up with the 0 on the timing tab, and the firing order of the plug wires installed correctly....it should technically fire up and run...correct?
I did, it was bone dry before I re-installed the carburator stuff...
When I spray starting fluid in the carb it runs for a quick second....I mean you count to 1 and that's how long it tries to run. ...
Yup. Did you check to see that you really have a spark or just assumed?
