1978 Center Console Light
Old Dec 6, 2009 | 02:43 PM
isbellboxman's Avatar
isbellboxman
Default 1978 Center Console Light
Does anyone have a diagram of the Center Console Light Unit for a 1978? I replaced the the upper light bulb housing but there was nothing to complete the circuit from the bulb to the two wires connected to the housing. I think I am missing a part. Thanks for your help.
Old Dec 6, 2009 | 03:04 PM
...Roger...'s Avatar
...Roger...
Remember it takes a special bulb for that socket.
Old Dec 6, 2009 | 03:56 PM
RedZR's Avatar
RedZR
Speaking of console lights- my 78 does not have any lighting at the heater controls or the shifter.
Are there lights for those areas? I did not see any loose wires or empty light sockets when I was fixing the heater selector assembly.
Dan
Old Dec 6, 2009 | 04:03 PM
...Roger...
Its the one in the pic above. To get it to work right it needs the special bulb with the lens on the end.
It shines down on the heater controls.
Old Dec 6, 2009 | 04:06 PM
isbellboxman
Thanks, I have power and ground on the two wires that connect to the housing, but but there is nothing on the housing to complete the circuit to the bulb. Am I missing something? Thanks
Old Dec 6, 2009 | 04:11 PM
isbellboxman
Thanks, I'll make sure I get the correct bulb.
Old Dec 6, 2009 | 04:16 PM
...Roger...
See the socket sitting at the bottom of the pic ? The brass ears make contact when the socket is in place.
Old Dec 6, 2009 | 04:30 PM
RedZR's Avatar
RedZR
Where is it located- at the top or bottom of the center consoles (where the gauges are)?
Dan
Old Dec 6, 2009 | 04:59 PM
...Roger...
Dan
Its at the top of the cluster above the gauges,shines through a tiny hole.
The pic above shows the back side of it.
Old Dec 7, 2009 | 04:21 PM
batmedic's Avatar
batmedic
Sorry don't mean to barge in, but Roger do you have the info for that light. Mine had a standard bulb that wasn't working. I changed it and still doesn't work. Should the light turn on anyway? Or does this only work with that light? Thanks.
Old Dec 7, 2009 | 04:31 PM
...Roger...
I think this is it,but I'll go out to the garage and get you the Delco number so you can cross it.
http://willcoxcorvette.com/product_i...ducts_id=26365
edit- The light turns with the other dash lights. Check the gray wire for 12v when the lights are on and the black wire for ground.
Delco #L-558 GM # 9433183
To 1978 Center Console Light
