High RPM SBC ?
Old Dec 9, 2009 | 09:33 AM
Rmorgan&11's Avatar
Rmorgan&11
Default High RPM SBC ?
I want to build a SBC that will turn some R's .
Before I do What is a Great CI Combo ?
I have a friend who spins his BBC to 7200 in a Chevelle and my Boat turns 6500 on a 3/8" rod bolt basicly stock lower end BBC (ARP & other good parts used ) factory crank etc..
I would like to see a usable rpm up to about 7k or better ? ..my car is 4sp w/3.36 gear
I have a 400 shortblock and a (327 sm.journal shortblock that is already built, but the crank is cut .120 /.90 ) so I 'm shying away from this one
Old Dec 9, 2009 | 09:41 AM
gkull's Avatar
gkull
modern forged cranks and rods rarely have rpm related problems. The valve train does.
So put a 3.875 stroker in that 400 block and build it to do 7800 rpm. No problem 421 ci and it should be in the mid 600 hp.
Old Dec 9, 2009 | 10:01 AM
Rmorgan&11's Avatar
Rmorgan&11
gkull >
any preferrred rotating assy.mfr.???
in my BBC the Top End is all Roller w/$$$ Parts
I want something streetable , but able to stretch its legs on these long open texas roads
Old Dec 9, 2009 | 10:21 AM
bashcraft's Avatar
bashcraft
Is that 400 block a 2 bolt or 4 bolt main? If it's a 4 bolt, don't use it.
Old Dec 9, 2009 | 10:25 AM
billla's Avatar
billla
St. Jude Donor '14
I've built a 7500 RPM 350 that's still going after 3 years (crossed fingers)
Gkull's right on, as usual. Top-notch forged rotating ***'y, solid roller cam and mondo heads, everyting balanced to a tee and held together with ARP studs
Old Dec 9, 2009 | 10:29 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My 427ci will still be making power at 7500RPM you need to spend some money though. I like Callies cranks and if I did it again I would get a set of lighter I beam rods and the pistons I have are OK as they are pretty light. ( Sure there's even better stuff out there but this will do )
Key here is valve train and I would recommend shaft rocker setup. Once you have one you will never go back to stud rocker setup they are so stable.
And for 400 based motors you need big heads nothing under 220's and big solid roller cams
Old Dec 9, 2009 | 10:36 AM
Rmorgan&11's Avatar
Rmorgan&11
after I went roller top end on my BBC , never go back to flat tappets again ..
I have some other blocks and parts for my BBC I can sell to bring in alot of the funds, I don't have much time to race the boat anymore so I may sell it too ?
Old Dec 9, 2009 | 10:51 AM
MotorHead's Avatar
MotorHead
You may need to sell the boat to build what you are looking for, I paid almost twice as much for my motor as I for the Vette
Old Dec 9, 2009 | 11:03 AM
Rmorgan&11's Avatar
Rmorgan&11
may just pull the motor out of the damn boat
It's pushing some HP
Old Dec 9, 2009 | 11:12 AM
MotorHead's Avatar
MotorHead
Probably the easiest and cheapest route
Old Dec 9, 2009 | 11:15 AM
gkull's Avatar
gkull
gkull >
Higher RPM just kills motor longevity. So I build my motors to feasably withstand 8000 rpm and then cam them down and put a rev limiter to 7000 and then they last........... most of the time.
I lost a 355 ci motor just trying to maintain 6500 rpm for 90 some miles in testing for a Nevada open road race. It is really hard on motors to stretch it's legs as you put it for any length of time.
I also broke the crank shaft on my first 427 small block. It was a 4340 cheap forged crank that couldn't handle running it to 7500 in the first 4 gears.
big ci is the way to go to get Vette to go from "Zero - 175 mph" in a hurry
I have bought a few of the over $3000 dollar rotating kits for small block from these guys.
www.flatlanderracing.com
Old Dec 9, 2009 | 01:01 PM
Little Mouse's Avatar
Little Mouse
Somehow ford won four 24 hours lemans races with 1960s knowledge.
Old Dec 9, 2009 | 01:18 PM
bashcraft's Avatar
bashcraft
FE bottom ends are really tough. The "Y" block with cross bolted mains and the LeManns capscrew rods were pretty much bullet proof. I've had several big block Mustangs and never once lost a bottom end. My problem was alway broken valves. No doubtedly from the valves floating.
Old Dec 9, 2009 | 01:20 PM
MotorHead's Avatar
MotorHead
I wouldn't bother with a stock OEM 400 block either if you are thinking 7500RPM that is mandatory aftermarket block with billet steel main caps ARP hardware everywhere
Old Dec 9, 2009 | 01:25 PM
gkull's Avatar
gkull
I work on historic race cars. Even a real gt-40 and it is going to Le'Mans this spring. Back in the day for qualifying they used qualifying power engines and or changed the rpm limits compared to the endurance motor for the 24 hour race. We use modern rev limiters to keep the owners from blowing vastly superior modern built motors. On this GT-40 we also over geared it so it can not even get near red line in top gear. Where in qualifying motors you hear them bouncing on the rev limiter on the main straights
Just like a drag racing motor can last for a years worth of 1/4 mile bursts, but that same motor couldn't do a 500 miles trip on the interstate.
Old Dec 9, 2009 | 01:39 PM
Little Mouse
289 based engines had to turn some revs to make the power they claimed in the GT40s. very small cube
limit at 5.0 liter limit.
The 289 did not have a strong cross bolted block like the 7 liter ( 67
Mark 4 winner )
One thing good about the 289 it only had 2.25 size mains, slow bearing speeds, very short deck, light short rods, light pistons. Its lot easier to turn short strokes, very light parts around a circle for long periods of time,
much easier on parts, blocks.
but having said all this the old 426 and 427 nascar engines were turning
7600 rpm down the straits for several hours at a time.
Old Dec 9, 2009 | 01:42 PM
Manuel Azevedo's Avatar
Manuel Azevedo
This depends on what you are really trying to do here. On most all street type engines the valve train in the limiting factor. You need good valve springs and good rockers on a shaft or with a good stud girdle. The shorter the stroke the easyer it is on the engine for high rpms also by reduceing the piston speed, and piston speed is the killer on the lower end. Long stroke and small main journual are another killer on rpm engines. That 327 you got should have a steel crank being a small journal crank and with a good valve training will have NP in the rpm range you say you would like. But your statement of the crank being cut ".120/.090" ?? what are you talking about here? Under sizes only come to .060 under for this engine!
To High RPM SBC ?
Old Dec 9, 2009 | 02:26 PM
gkull's Avatar
gkull
We should not banter in someones post. But it takes a well built motor to stretch it's legs for a long period of time. I would not use the term several hours when in fact the old LeMans cuircut had only @8 mile straight. Most fast cars would only be doing max revs for sub three minutes at a time. Compared to open 92 mile road races that last for 20+ minutes.
Big ci and lower rpm is my preferred choice on motors. So did Ford when they decided to race 427's against the tiny 3000 cc european cars
Old Dec 9, 2009 | 02:55 PM
Little Mouse
I agree with you, if you can turn less rpm make the same or more power its almost always a good thing, even the big blocks were short stroke big bore engines. kind of funny when enzo complained about the 7.0 liter ford got the rules changed to 5.0 liter limit, ford dropped out, gulf oil took a five liter mark two same car 68/69 still kicked enzos behind with it lol.
I watched chasing classic cars last night the 289 datona coupe that won the SCCA championship ( ford only american manufacture to do it ) at auction went for seven million two hundred fifty thousand in this bad economy.
Old Dec 9, 2009 | 03:10 PM
pewter-FRC's Avatar
pewter-FRC
stock 400 block here bored .040 cast crank, stock short rods, studded the 2 bolt mains and arp rod bolts, hyperutectic pistons, not even balanced. in a 3900 # car for 6 years. spin it to 7200 while blowing nitrous thru it. its an $800. swapmeet shortblock. years ago my $8000. + sm block with all the good stuff made 1 pass and kicked a rod out. go figure. used to run the stock 283 to 8000 rpm with a 4-speed and 5:38 gears. never had the pan off, bone stock shortblock from 1961
