lifter tapping :-(
Old Dec 10, 2009 | 08:37 PM
glarior's Avatar
glarior
Default lifter tapping :-(
Well.. I have a lifter that taps now. Sounds like cylinder #7
Anything I can do to fix that with out replacing it all? I readjusted all the lifters last week but that one is still tapping. 1980 L48 -stock
Old Dec 10, 2009 | 09:22 PM
midyearvette's Avatar
midyearvette
check for a wiped lobe especially on an 80...good luck
Old Dec 10, 2009 | 09:27 PM
WhiteC3's Avatar
WhiteC3
I had to change cam with #7 exhaust lifter wiped. I also replaced the oil pump with new cam to make sure it gets plenty of lube so maybe it will last till rebuild.This looks like the third cam my engine had. Sounds like your vette has broom stick disease too. Make sure to use good oil with Zinc like valvoline VR1 racing oil or whatever you prefer.
Old Dec 10, 2009 | 09:34 PM
WhiteC3's Avatar
WhiteC3
Was thinking about it some. Could be faulty lifter hydraulic unit. You can remove valve cover and check for a weak lifter by pushing on rockers (pushrod end) with valves closed.
maybe that will help figure it out before tearing into it.
Old Dec 10, 2009 | 10:02 PM
dannyman's Avatar
dannyman
I'll throw this out from a different perspective, having been mislead in the past myself.
Did you check for an exhaust leak at that location or have you verified that it is lifter noise by a stethoscope? An exhaust leak can be quite similar in noise.
Old Dec 10, 2009 | 10:25 PM
glarior's Avatar
glarior
Thats what we are thinking right now.... faulty lifter hydraulic unit
I wish it was an exhuast leak.. in fact I was really hoping it was. I did not use a stethoscope just my ear and my fathers. We both agree.
Old Dec 10, 2009 | 10:33 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There may be some dirt stuck in the lifter!
In the old days we would change the oil and instead of 5 quarts of oil we would run 4 quarts oil and 1 quart tranny fluid. The tranny fluid is a higher detergent then the oil and sometimes it will work.
Might be exhaust spit, cam issue, lifter issue and/or one or more of the above. You might try the cheap route first. Run it a little while and see what happens.
Willcox
Old Dec 10, 2009 | 11:48 PM
67tripwr's Avatar
67tripwr
I had a similar problem on my 427, and as it turned out the push rod was defective! The end of it had failed!
I had the cam lobe checked, and it was fine! Pull the noisy push rod and check it. Could also be a stuck piston on the lifter.
Get that oil filter cut open, and check for metal inside. If the lobe on the cam is toast, this should reveal it.
That is the first step actually, checking what resides in the filter. Then get the lobe checked out!
If you find allot of metal in that filter, a tear down and go through would be advised! That stuff will prematurely devastate bearings etc....
After I installed the new push rod, it was explained, that if the lobe was failing it would be revealed in short order. It was fine!
Old Dec 11, 2009 | 05:58 PM
leetownreb's Avatar
leetownreb
It's a Chevy--it's not running right unless there's a ticking........
Old Dec 11, 2009 | 06:35 PM
Phil Zell's Avatar
Phil Zell
Willcox
Ditto
Old Dec 11, 2009 | 07:17 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Old Dec 11, 2009 | 10:02 PM
not a '76's Avatar
not a '76
when i had 'lifter tick' it turned out that the retaining wire in the lifter had come undone leading to the lifter basically being half-dissassembled inside the motor. so certainly there are many possible reasons for a lifter tick and the only way to find out whats wrong is to dive in from the outside in until you find the problem.
good luck.
Old Dec 11, 2009 | 10:24 PM
WhiteC3's Avatar
WhiteC3
If you don't know what it is,find out what it's not....... That is the method I use. Start with the cheapest first.Probably if nothing found under valve cover,pull the intake it's easier than it looks I can do a remove and install in under 2 hours. The trick is to glue the gaskets to the intake with fast tack sealer and hold it in place with magnets for a hour or so.
Old Dec 12, 2009 | 10:22 AM
08vycpe's Avatar
08vycpe
I had a '77 Vette years ago that had a noisey tappet. It turned out that several push rods were bent. I must have over reved the engine at some point. I replaced the push rods and all was well.
If you roll the push rods on a flat surface a bent push rod will be obvious.
Note: Be sure to reinstall them in the same location they came out of.
Old Dec 12, 2009 | 12:04 PM
billla's Avatar
billla
St. Jude Donor '14
Another "trick" is to spray some carb cleaner down the pushrod. Not a ton, but a spritz.
If you've adjusted that valve, then it's probaby time to think about pulling the intake and having a look. It's the weekend, go to it
Old Dec 12, 2009 | 01:35 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Not to hi-jack, but what happened if you place a new lifter (or a set of new lifters) on a used camshaft? .. is it ok and be ready to go? , is it ok but need to redo a break-in? .. or is it not ok at all?
Old Dec 12, 2009 | 01:46 PM
midyearvette
you can put new lifters on a used cam but not the other way around unless it is the same lifter used on that lobe....having said that, back in the day we did it the suppossed wrong way with no ill effects....
To lifter tapping :-(
Old Dec 12, 2009 | 01:49 PM
midyearvette
good luck.
i agree:
it's a hell of a lot easier to check for a wiped lobe, bad rocker, bad or bent pushrod by simply pulling the valve covers and starting or spinning the mill by hand......good luck...
Old Dec 12, 2009 | 02:11 PM
billla's Avatar
billla
St. Jude Donor '14
Opinions differ, but new lifters on a used cam is generally fatal. Used lifters on a new cam is generally fine.
Old Dec 12, 2009 | 02:17 PM
midyearvette
like you say.opinions do differ but if you quote all the cam grinders ( who love to sell stuff!), that is the preferred method...from personal experience i have done it each way and violated all the so called rules without a problem.....that was back in the good old days when i was broke!......
