Rear main ? (HELP)
Old Mar 2, 2002 | 12:43 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Rear main ? (HELP)
Ok I removed the oil pan and oil pump. The crank looks dry, no oil on it. I think my oil leak may be coming from another location and dripping down through the convertor cover. Should I go ahead and change it or let sleeping dogs lie? I hate oil leaks.
Old Mar 2, 2002 | 12:53 AM
trw's Avatar
trw
Default Re: Rear main ? (Budman78)
when you say the crank is dry?? I would think that as you have it apart, do it!!
After it is back together, if you still have leaks, then clean the exterior of the engine and find the leak.
Rear main is easy, since you already have it apart.
Terry
