Valve Covers
Old Dec 12, 2009 | 04:38 PM
bigvette1's Avatar
bigvette1
Default Valve Covers
Here is my dillema,
I have a 73 - 454. The stock valve covers even with 2 gaskets are very close to having the rockers (especially a true roller) hit the cover when running. I would like to go to tall ones 3 5/8", but the stock location of the alternator is about 1/2 over the valve cover. Hence, almost any cover except stock hits the side of the alternator.
Has anyone modified the location of the alternator to mount just outside the valve cover so a taller cover can be added? I see from photos that most small blocks have the mount outside the cover.
Old Dec 12, 2009 | 08:49 PM
Knut-71's Avatar
Knut-71
8th Gear
I had a similar problem on my 454 with a roller cam. I found this web site which sells valve covers that are slightly taller than original, at 2-3/4 tall. They resolved my double gasket issue.
http://www.cfrperformance.com/Chevy_...overs_s/43.htm
knut
Old Dec 12, 2009 | 08:53 PM
bigvette1's Avatar
bigvette1
KNUT,
Thanks and I looked and saw the chrome and the orange at 2 3/4" Are these the ones you used? Did they clear the alternator back side? Thx
Old Dec 12, 2009 | 11:08 PM
Ironcross's Avatar
Ironcross
just get a longer belt and see if that helps as long as the adjusting bracket will swing far enough out...should if the alternator is on the left side
Old Dec 13, 2009 | 07:56 AM
3JsVette's Avatar
3JsVette
If you really want to keep the stock covers you can consider something like this. http://www.speedwaymotors.com/Big-Bl...ign=GoogleBase
Old Dec 13, 2009 | 08:24 AM
bigvette1's Avatar
bigvette1
Good idea also on the spacers -thanks for looking. When good steel valve covers with the baffles and an oil fill hole cost 60-80 or more, the spacers at 80 make sense and use the stock ones.
On a bbc 73 the mounting brackets are fixed in length and that is where my problems is. There is almost no clearance on the bottom of the alternator to the left side of the valve cover.
Any ideas if other engine alternator brackets and arms would mount to the 454?? Thx
Old Dec 13, 2009 | 12:06 PM
Kfmorgan's Avatar
Kfmorgan
Originally Posted by bigvette1
Here is my dillema,
Edelbrock makes a tall chrome valve cover with breather holes and baffles, that will clear your roller rockers using stock gaskets. I use them on my modified ZZ454. The corner where the alternator is mounted, has to be massaged slightly with the judicious use of a ball peen, or body hammer. It does not interfere with the rocker arm, and can barely be seen once everything is mounted back. No alteration of the alternator bracket required. Reaching some of the hold down bolts, especially on the passenger side by the A/C box, and the A/C compressor (if you have A/C) can be a little difficult. I don't have the part# handy, but they are readily available, and relatively inexpensive.
Good Luck!
Old Dec 13, 2009 | 02:46 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Is your alternator bracket a big cast piece or a welded thin plate arrangement? If it's a plate arrangement like the 427 units you should be able to do some reasonably easy cutting and welding on it to move the alternator pivot point.
Old Dec 13, 2009 | 04:30 PM
Knut-71's Avatar
Knut-71
8th Gear
KNUT,
Bigvette 1
Yes, these valve covers did clear the alternator side and the recessed corner took care of the brake cannister. In addition, i ordered one THICK gasket from the same shop so I got the extra clearance. In my case, it worked out great. In the end, I painted my valve covers orange. It looks very original. Good luck.
knut
http://www.cfrperformance.com/CHEVY_.../hz-9504-t.htm
Old Dec 13, 2009 | 08:02 PM
bigvette1's Avatar
bigvette1
Thanks for all the info.
69427 - The lower bracket is cast and mounts to the front of the block and the exhaust manifold. Here is where you idea of maybe a little grinding and drilling is needed in order to pivot the alt. further out away from the valve cover. The top bracket is not just an arm or brace but a steel bracket for the top dog ear of the alt. I would have to get the brace style that allows the alt. to slide in and out.
knuts, I will seriously consider those covers from your experience along with some massaging of the bracket to help clear.
Old Dec 13, 2009 | 10:44 PM
ajrothm's Avatar
ajrothm
I just went through this today. You "can" shim the alternator forward. I put (2) 5/16" washers behind both mounting points of the alternator and the strap brackets. This effectively pushed my alternator forward about 3/16", just enough to clear the cheapy tall valve covers I had to install today. The alternator belt will be real close to the shroud though. I trimmed it a tad.
I was also running the stock chrome covers with 3 gaskets and the rockers were still hitting, not to mention the valve covers were leaking through the gaskets. I threw my cheapy tall covers on but thanks to Knut-71, I just ordered the stock looking taller covers from CFR.
Old Dec 14, 2009 | 11:14 AM
bigvette1's Avatar
bigvette1
Really interesting as I thought I was the only one with the problem of alt and valve cover interferance and rockers pounding the hell out of the covers and changing valve opening - along with poor running. Thx to all for the input and the problem will get fixed here, when it is warm enough to work comfortably in the garage.
Old Dec 14, 2009 | 12:03 PM
73StreetRace's Avatar
73StreetRace
Same problem here, outside temperature will be below 30°F all the week...
To Valve Covers
