Need some ZZ4 input...
Old Dec 14, 2009 | 08:16 PM
DaveL82's Avatar
DaveL82
I put a ZZ4 in my 80 vette several years ago and have been very pleased with the power. Remember the ZZ4 is a torque motor and yes HP helps but it's torque that spins the tires.
Mine makes 290 HP at the rear wheels with a stock rochester. I was down on HP at first and found the secondaries weren't opening all the way. My car will spin the tires no problem so I suspect carb, ignition or major exhaust restriction
Old Dec 14, 2009 | 10:05 PM
Taijutsu's Avatar
Taijutsu
Default Dyno Time?
I thought my 74 was not too bad, until the dyno tech found 80 hp!
I agree that you need to make sure you are getting proper ign and carb is opening properly. After that you can think about what to do next!
Are you running fresh wires, cap, rotor? These things together can make a big difference.
The ZZ4 is a little over rated, but it can be made to do whatever you want done. JMHO
R
Old Dec 14, 2009 | 10:22 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Check to see if your getting full throttle. If they used the Q-jet throttle cable bracket with the Edelbrock, your probably not ever at full throttle. Have someone push the throttle pedal all the way down, and look at where your secondaries are at. I had that problem at first and I was down a good 60Hp.
I also recommend that your recurve the HEI like someone else suggested. It made a world of a difference to the throttle response.
With GM's hot cam and a home port job of the L98 heads, I'm running consistent low 13's, with a best of 12.8 sec 1/4 miles. This is with the car setup for road courses, so it's not even optimized for the strip.
Here's my dyno sheet at the rear wheels.
Old Dec 15, 2009 | 12:37 AM
rellim51's Avatar
rellim51
After driving it the last couple of days, I had to reset the timing tonight. Previously, I had to set the initial to 18deg to get the total to 34deg or so. It ran ok but it pinged on light acceleration. MPG decreased drastically also. I reset the initial back to 12 deg. I think the total now is 26-28deg @3000 rpm. When I had the idle set at 3000 rpm to set the total, I noticed a slight popping noise from the tail pipe, and I've noticed a slight rocker rattle noise when driving. Could the valves need to be readjusted? The car seems to run really strong at WOT and just off idle, but it feels flat and almost feels like it is missing under half throttle acceleration. It seems to go away if I increase throttle to WOT. I'm a little confused about that part. I'll see if the local parts store has a recurve kit for the dist tomorrow. I have a stall converter left over from another project I'm planning on installing over the holidays. It's a TCI Sizzler. It's not much but I've already got it so it's worth a try I guess.
Old Dec 15, 2009 | 07:47 AM
TopGunn's Avatar
TopGunn
You shouldn't be pinging @34 deg if the fuel is good, I suspect you're getting too much advance before 3,000 rpm as I previously stated. Bringing the timing back to 34 to stop that hurts you in the long run, that's exactly the delima I was referring to before.
If you're hearing a popping noise combined with rocker noise, you could have a valve train issue. Those are hydraulic lifters, once properly set they should not need adjusting and should be very quiet. Has someone changed the rockers to roller tips by any chance? Those sometimes are noisy.
Make certain your rotor, distributer cap, wires and plugs are in order. Pull the valve covers, look at the rockers verify they are stamped and original and adjust them properly for a hydraulic roller lifter.
Also, some good advice given above about checking the throttle linkage to make sure the throttle plates are opening 100%.
Old Dec 15, 2009 | 08:20 AM
TPIShark's Avatar
TPIShark
My ZZ4 is fuel injected, but my best ET to date is 12.85 @106. (3:55 gears)
Old Dec 15, 2009 | 08:41 AM
DaveL82's Avatar
DaveL82
You must set up the initial timing correct and then work on the advance issue. Do not let the motor ping as the hypereutectic pistons don't like it at all!
Your best money spent is not on new HP parts but a dyno run so you see if the carb is working right and if there is a mixture or timing issue. Make sure you find a place that knows carbs.
You've got some good parts there to make a fun ride so I think it just needs a bit of tuning.
Old Dec 15, 2009 | 07:54 PM
rellim51's Avatar
rellim51
I got the recurve kit tonight but didn't have time to mess with it. I've noticed, at part throttle, acceleration it is very flat and it seems to miss at upper rpms but as soon as I go to WOT the miss goes away, and it pulls very hard. I know the timing needs some attention to get to 36deg total while maintaining 12deg initial but I don't see how this would cause the miss. I have replaced the cap/rotor/ wires and the plugs look new. I would love to take it to a dyno but the closest one is probably 300 miles away. As a side note, I found some old receipts where the PO had the car to a couple of different shops with lack of power being the complaint. Not repairs were ever made according to the receipts.
Old Dec 19, 2009 | 05:33 PM
rellim51's Avatar
rellim51
Well I got the dist. recurved and the timing is where it should be. Still no power. Runs ok a WOT but anything less than WOT and it is a DOG. Still can't even break the tires loose from a dead stop.
Old Dec 20, 2009 | 03:15 PM
FKING1's Avatar
FKING1
What carb are you running? That could be the problem.
Also, a 3.08 is not a very good ratio for burnouts. Too high.
Old Dec 20, 2009 | 03:38 PM
rellim51's Avatar
rellim51
I'm running an Edelbrock 750 electric choke carb. I'm going to try more tuning on it and see what happens.
Old Dec 21, 2009 | 04:24 PM
FKING1's Avatar
FKING1
When I went up 5 jet sizes on my Holley 670 Street Avenger,primary & secondaries, the motor went from night to day in terms of performance. Also, when installing the carb, I initally didn't realize there were 2 fuel inlets on the carb and quickly found out it would run good at steady state , but, a dog otherwise.
Old Dec 21, 2009 | 09:50 PM
  #33
gatorbcn's Avatar
gatorbcn
I think you will find that someone who knows carbs can really wake that motor up. All the other stuff (intake, cam, torque converter, gears) is gravy. Good luck!
