What are these three knobs under the dash?
Old Dec 13, 2009 | 07:27 PM
taz7nads's Avatar
taz7nads
Default What are these three ***** under the dash?
Under the dash in the center, there are two small "pull down" ***** on either side of a "turn" ****. If I remember correctly, the pull down on the left is the headlight override, which keeps the headlights from closing. Don't know what the pull down on the right is, or the large round **** in the center. I'm sure they also have to do with the vacuum system, but as I don't have it re-done yet, I'm not sure. ('70 Coupe)a
Old Dec 13, 2009 | 07:46 PM
'75's Avatar
'75
The pull down **** on the right is the wiper door over ride. The turn type **** is pushed in and turned to reset the trip meter.
Old Dec 13, 2009 | 07:52 PM
Gordonm's Avatar
Gordonm
The center one you can turn it and it leaves the wiper blades exposed so you can change them. It is an electrical switch and the other two are vacuum switches.
Hammerhead Fred's Avatar
Hammerhead Fred
The left pull raises the headlights, the right pull raises the wiper door, and the **** in between them is a switch which stops the wipers so you can inspect/change the blades. So, if you open the wiper door and start the wipers you can stop them mid windshield by turning the **** a quarter turn counter clockwise. The **** simply cuts off the power to the wiper motor.
Old Dec 13, 2009 | 07:53 PM
'75's Avatar
'75
oops, my bad
Old Dec 13, 2009 | 08:47 PM
taz7nads's Avatar
taz7nads
thanks, guys. Once again, this site has proven indispensible.
Old Dec 13, 2009 | 09:04 PM
Solid LT1's Avatar
Solid LT1
Recalling from the movie #1 bullet proof shield, #2 ejector seat, #3 oil spray from rear of car
Old Dec 14, 2009 | 10:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order a reproduction owner's manual. Lots of valuable information in the owner's manual.
Old Dec 14, 2009 | 12:08 PM
73StreetRace's Avatar
73StreetRace
You're watching too much James Bond movies... but I think he often drives Aston Martins, not Corvettes.
Old Dec 14, 2009 | 01:37 PM
BobRBob's Avatar
BobRBob
On his model, #3 is the Maverick missile launcher, not the oil spray.
To What are these three knobs under the dash?
