PCV valve,can I remove?
Old Dec 16, 2009 | 04:39 PM
  #61
fauxrs's Avatar
fauxrs
Originally Posted by Avette4me
3 pages on Polyvinyl chloride? really where?
Old Dec 16, 2009 | 04:54 PM
  #62
pippo350's Avatar
pippo350
This forum it's really funny!
I think the right place where you can learne more on your Vette.
Old Dec 16, 2009 | 05:22 PM
  #63
CCrane65's Avatar
CCrane65
I had a '65 Corvette with an L79. These engines were designed with a blowby tube on the back of the intake manifold and a rubber hose than hung down the back of the engine.
Made quite a mess on the underside of the car and even dripped oil on the pavement.
As we all know, oil, especially used oil, is not good for the ground and lord knows we get enough of it everywhere anyway.
Golden, I have to tell you that maybe one little car or even a few race cars won't make any difference but billions of them blowing used oil all over the place will absolutely have an effect. And over time the effect is compounded.
Removing the PCV is not unlike what Bubba does with most things. If he doesn't understand it and he 'cain't figger it out' he disables it.
Geez, a little valve that ensures the crankcase has room for fresh air by removing the nasty stuff already in there...what's the big deal. It's not a conspiracy for crying out loud.
People always ripped the A.I.R. pumps off too thinking they robbed them of horse power. Yes, they are parasitic because of the belt but that's about it. They just pump fresh air into the exhaust manifolds. No power robbing there. It's all downstream of the combustion process.
Good grief.
Old Dec 16, 2009 | 06:34 PM
  #64
Golden's Avatar
Golden
Are you suggesting I'm some kind of ignorant simpleton that doesn't understand what they're doing?
You clearly either haven't read the thread or have no grasp what so ever of what PCV is and it's implications.
Good grief.
WHAT! air pumps rob power to run, cause turbulence in the headers, raises manifold temperature, compounding the turbulence, reducing cylinder scavenging, lowering cylinder VE.
Before you start posting pompous replies I suggest you know what you're talking about.
Old Dec 16, 2009 | 06:48 PM
  #65
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
This one is becoming yet another classic thread on PCV's...
Old Dec 16, 2009 | 06:52 PM
  #66
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
After reading through this thread, it appears to me that you're either out to prove how much of a genius you are or how much of an asshat you can be.
The latter is really beginning to shine...
Old Dec 16, 2009 | 07:02 PM
  #67
Golden's Avatar
Golden
Do you do stand up?
Old Dec 16, 2009 | 07:08 PM
  #68
pauldana's Avatar
pauldana
Originally Posted by Mike Ward
Yes, and they're not done yet.
Yes, they are
No, they're NOT.
Yes they ARE!
You shut up.
No, YOU shut up!
etc.
that and Brake rotors....
Old Dec 16, 2009 | 07:36 PM
  #69
Avette4me's Avatar
Avette4me
Do you do stand up?
I probably have to put my hand up on the latter at times, if that's what you mean. You just seem to be trying pretty hard to prove something. Comes off as rude to me, that's all.
Old Dec 16, 2009 | 09:24 PM
  #70
FB007's Avatar
FB007
Wow. Quite the arrogence from the land of SU carbs, Lucas electrical, and warm beer. How's that British space program going?
Old Dec 16, 2009 | 09:33 PM
  #71
FB007's Avatar
FB007
Golden, let me try this another way. I can't wait to read your response. Blowby is simply the transference of gases from the "right" side of the rings, to the "wrong" side of the rings. A PCV merely takes the gases from the "wrong" side of the rings, and places them back into the "right" side.
If the escaped gases originate in the "right" side in the first place, what "harm" will they do the second time thru?
Old Dec 16, 2009 | 10:48 PM
  #72
CCrane65's Avatar
CCrane65
FB007, I'm thinking it's a lost cause. There's no cure for...well you know.
cc
Old Dec 16, 2009 | 11:45 PM
  #73
73, Dark Blue 454's Avatar
73, Dark Blue 454
To those that argue against the use of a PCV system, what's your suggested alternative? A pair of breathers?
Old Dec 17, 2009 | 09:23 AM
  #74
CCrane65's Avatar
CCrane65
The thing I have against using breathers in the valve covers is that it forces the crankcase to use the same pathway for pressure release that was designed as an oil return from the rockers so you already have oil in the path and the built up pressure pushes it back up toward the breather.
Not very efficient. The PCV valve uses one valve cover to vent pressure to the combustion chamber via the carburetor and the other to pull in fresh filtered air to replace it.
Given the above scenario you have increased the oil return capacity by up to 50% while providing a positive relief for internal pressure from the crankcase.
This also increases the life of the oil by removing the contaminants in blowby from the crankcase.
I have not seen a down side to the PCV system at all when used and maintained as designed.
If you are concerned about oil in the intake manifold, GM makes a product called Top Engine Cleaner you might consider using every so often. It was made specifically to clean out the intake.
cc
Old Dec 17, 2009 | 10:22 AM
  #75
73StreetRace's Avatar
73StreetRace
I think each time someone starts a new thread about PCV, it always ends the same way...
Old Dec 17, 2009 | 12:12 PM
  #76
63mako's Avatar
63mako
St. Jude Donor '08-'09
75 posts on PCV. one poster against that thinks everyone that disagrees with him is an idiot and does not mind telling them so.
Old Dec 18, 2009 | 06:26 AM
  #77
Golden's Avatar
Golden
What do all these things have in common.
McLaren F1 Team
Mercedes F1 Team
Redbull Racing F1 Team
Williams F1 Team
Force India F1 Team
Lotus F1 Team
Virgin F1 Team
Frederick William Lanchester inventor of disc brakes.
Herbert Akroyd-Stuart inventor of fuel injection.
Butler inventor of the venturi carburettor.
Maybe some names you've heard of.
Lola
Raynard
G-Force
Ilmor
Cosworth
To PCV valve,can I remove?
Old Dec 18, 2009 | 07:20 AM
  #78
Golden's Avatar
Golden
Increased carbon build up in the combustion chamber, disrupted airflow in the carburettor, increased intake charge temperatures, increased carb running temperature, reduced cylinder VE, reduced HP.
A pair of open filtered breathers or one or two filtered catch tanks.
Even if you had an engine with such bad piston blow-by it could hardly run, it still wouldn't create enough pressure to stop oil flowing through relative large head and block castings.
This may have been true in the 60's with basic mineral oil and no additives. Today's oils will easily tolerate even excessive blow-by.
Also let me remind you again that many more modern engines do not have PCV just a closed breather system. If oil and crankcase contamination was such an issue don't you think all manufacturers would use PCV?
Some of you really need to join this millennia.
Old Dec 18, 2009 | 07:38 AM
  #79
73StreetRace
Ding, Ding, Ding !
End of round one !
And the winner is...
Old Dec 18, 2009 | 08:28 AM
  #80
FB007's Avatar
FB007
McLaren F1 Team
Mercedes F1 Team
Williams F1 Team
Force India F1 Team
Lotus F1 Team
Virgin F1 Team
Lola
Raynard
G-Force
Ilmor
Cosworth
Bad teeth?
