PCV valve,can I remove?
Let me say this one more time (I think the 3rd time) in the vain hope you actually read it.
PCV was developed in the mid 60's to reduce smog.
During World War II a different type of crankcase ventilation had to be invented to allow tank engines to operate during deep fording operations, where the normal draft tube ventilator would have allowed water to enter the crankcase and destroy the engine. The PCV system and its control valve were invented to meet this need but the need for it on automobiles was not recognized. [/quote]
In 1952, Professor A. J. Haagen-Smit, of the California Institute of Technology at Pasadena, postulated that unburned hydrocarbons were a primary constituent of smog, and that gasoline powered automobiles were a major source of those hydrocarbons. After some investigation by the GM Research Laboratory (Dr. Lloyd L. Withrow) it was discovered in 1958 that the road draft tube was a major source, about half, of the hydrocarbons coming from the automobile. GM's Cadillac Division, which had built many tanks during WWII, recognized that the simple PCV valve could be used to become the first major reduction in automotive hydrocarbon emissions. After confirming the PCV valves' effectiveness at hydrocarbon reduction, GM offered the PCV solution to the entire U.S. automobile industry, royalty free, through its trade association, the Automobile Manufacturers Association (AMA). In the absence of any legislated requirement, the AMA members agreed to put it on all California cars voluntarily in the early 1960s, with national application following one year later
Let me try and catch you dinosaurs up on 40 years of engineering.
Oil - Now it's capable of going 10-15-20K before changing, it can do this because of the refining process, it's multi-weight, has longer polymer strands, plus the addition of stabilizing and detergent additives. The hydrocarbons they may have damaged 1960's oil now barely touch modern oil.
Also wanted to comment that engine analyzers and scopes have been around since the late 30's and were pretty common place by the 60's on this side of the atlantic
]A computer controlled PCV??? haven't heard of one those yet
I can tell you all these are true because cars that only have a non-positive closed system will regularly do 250-500k with no engine overhauls.
If you close a system it has to go positive by design.
on the other hand An open system is not a closed system
Also a car going 200 to 500K miles is quite unusual. Maybe you were talking kilometers which would be a bit more possible but still uncommon
Enviromentally IMPOSSIBLE
Imagine what the air quality would be like in any major metropolitan area (LA, NYC) would be like today had the issue of crankcase emissions not been addressed.
Through all of you BABBLING you offered no proof of the detriment caused by using a PCV system with or without a valve just your opinion.
The motor makes good vacuum, at least 12" so I am not sure why the PCVs spaz out but they damn sure do.....I guess I'll be opening the hole in the ozone bigger with my oil vapors....
The closed ventilation system is what's used on our C3's which uses a PCV valve and fresh air pulled into the crankcase by vacuum from the carb.
An "open" crankcase ventilation system used in the 40's, 50's and 60's (up 1968 on Chevy's) used a draft tube which pulled harmful vapors from the crankcase as the tube 'drafted' down the road.
Here's a schematic of an "open" crankcase ventilation system:
http://www.tpub.com/content/armyordn...OD10010120.htm
"As an engine runs, gases from the cylinders leak past the piston's sealing rings into the crankcase (containing the crankshaft and other parts). This leaked gas is sometimes referred to as "blow by" because the pressure within the cylinders "blows" them "by" the piston rings. These gases include compounds harmful to an engine, particularly hydrocarbons (unburned fuel), as well as carbon dioxide and water vapor. If allowed to remain in the crankcase, or become too concentrated, the harmful compounds will condense out of the air within the crankcase and form corrosive acids and sludge on the engine's interior surfaces. This can harm the engine as it tends to clog small inner passages, causing overheating, poor lubrication, and high emissions levels. To keep the crankcase air as clean as possible, some sort of ventilation system must be present."
The above is from here:
http://www.yourautonetwork.com/pcv_valve.html
And I'm still awaiting one credible document recommending the use of a pair of breathers vs. a PCV system. Again, here's a good place to start: www.google.com
FB007
TJP440
73, Dark Blue 454
leetownreb
I shall not be answering your comments as you have demonstrated insufficient knowledge to understand the conversation.
In the same way it's pointless for a brain surgeon to explain to a medic how to remove a brain tumour, I wont be drawn in to a discussion with people who lack the necessary training to understand the subject matter.
FB007
TJP440
73, Dark Blue 454
leetownreb
http://en.wikipedia.org/wiki/Flat_Earth_Society
Simply putting a laughing smiley on the end of a post doesn't make it funny.
Neither statement has anything to do with the other.
It's like you asking if I copy and pasted something.
Then my response being.
"Funny you should say that, how long are Americans going to keep taking credit for capturing a WWII Enigma machine".
OMG OMG that's soooooooooo funny!
FB007
TJP440
73, Dark Blue 454
leetownreb
