PCV valve,can I remove?
Old Dec 19, 2009 | 08:49 AM
  #121
FB007's Avatar
FB007
Originally Posted by Golden
Let me say this one more time (I think the 3rd time) in the vain hope you actually read it.
PCV was developed in the mid 60's to reduce smog.
Irrelevant to the arguement that they are detrimental or not.
The arguments that blow-by hurts the internals of the engine were based on that point in time.
Relevent. We are still talking about the same design
Let me try and catch you dinosaurs up on 40 years of engineering.
Oil - In the 1960's we were using very basic mineral oil, it had no detergent additive and was a single weight. It was so poor many vehicles required oil changes every 1000-3000 miles.
Fuelling - In the 1960's a gallon of gas cost 30¢, people didn't know or care what MPG was, if the car was off tune and dumping 3x the needed fuel into the engine no one cared. Likewise they didn't know or care about the black stuff coming out of the exhaust.
Tuning - In the 1960's cars were tuned by ear. If you were a real specialist you might use a vacuum gauge but that was it. Cars often ran excessively rich AF ratios, the driver didn't care as long as the car lit the rear tyres.
Development - As oils, fuelling and tuning improved many manufacturers disliked the idea that having spent millions on engine development they would leave the engine tune to 50¢ air leak. Unfortunately politicians still thought cars were the devils work so they compromised and used a non-positive closed system. This routed crankcase fumes to the air filter housing/box but allowed them to vent out themselves rather than using manifold vacuum to suck them out.
Whetrher above or below the manifold is irrelivant. It's still a low pressure area.
The Modern Day.
Oil - Now it's capable of going 10-15-20K before changing, it can do this because of the refining process, it's multi-weight, has longer polymer strands, plus the addition of stabilizing and detergent additives. The hydrocarbons they may have damaged 1960's oil now barely touch modern oil.
Fuelling - Look at peoples awareness of MPG, even you guys who often only use your cars on sunny Sunday still worry about MPG. This awareness makes you constantly concerned about how much fuel you're dumping into your engine.
Tuning - Today's carburettors are built mainly to run on the weak side of AF ratios, they are easier to tune and even if you take your orginial carb equiped car to the shop the tech uses a computerised engine analyser or maybe a chassis dyno, not his ear and guess work.
Development - Many engines designed after the 1960's don't use PCV, if the system is so essential why was this? It was because it was out dated, antiquated system that was no longer necessary. Today it is only fitted to cars sold in areas with the strictest emission laws and is often computer controlled.
Irrelivant. Modern cars are also fuel injected, which also reduces raw fuel in the crankcase.
So let me sum up.
Will an open system blow gaskets - noCorrect, and irrelivant
Will an open system cause sludge - noIrrelivant
Will an open system cause internal corrosion - noProve that one
I can tell you all these are true because cars that only have a non-positive closed system will regularly do 250-500k with no engine overhauls.Also irrelivant
Does PCV hurt performance - yesShow me the data.
Can an open system be clean - yesIrelivant
PCV belongs with stuff like cross-ply tyres and copper ignition wires, if you want to keep the car original then go with it. If you want performance throw it in the trash and forget about it.
You state that no one uses them anymore, than discuss a friends 07 Ford with one. It also contained moisture that you state will not harm modern oil. I guess water is an acceptable lubricant in your book.
You keep comparing modern tech with old. This engine was designed in 1955 or so. Most people retain carburetors that also wash the cylinder walls with more raw fuel than modern engines, which ends up as volatiles in the oil.
Show me some hard data that PCV on an old engine with modern oils is detrimental. Data, and less conjecture.
Old Dec 19, 2009 | 09:05 AM
  #122
FB007's Avatar
FB007
Originally Posted by Mike Ward
Speaking of that, I have a new hero in life- Lord Monckton. Please watch:
http://www.youtube.com/watch?v=OzkB5DuveDE
An educated man armed with biased statistics attacking an unarmed individual is your hero? Pathetic.
Old Dec 19, 2009 | 09:41 AM
  #123
Golden's Avatar
Golden
OK, I'm finally going to admit defeat in this thread.
I'm quite a tenacious person but even I have my limit, there are only so many times I can type the same cold, hard facts and try to reply to an argument of "you're wrong, and if you want me to prove it I'll just type it louder".
I'm fed up with trying to explain engineering fact to people who either skim read what I've posted or lack the fundamental background knowledge of the operation of the internal combustion engine to make an educated argument.
I cannot believe how backward thinking a few of the forum members are. How many people have to tell you the same thing before you'll believe it?
I only need to look through this forum to see technological ignorance reach a new level.
Carbs can out perform EFI, rubber bushes are better than Poly, points are better than electronic, drilled discs are a myth, I'm surprised you don't think your cars run on steam and witchcraft.
You're such sheep, the EFI situation is a good example, people dismiss it until a few key old fashioned players suddenly say it's 'ok', then on mass the rest of the pitch fork mob accepts it.
You thoroughly embarrass the rest the of the Vette community not living in the 1960's.
Old Dec 19, 2009 | 09:54 AM
  #124
FB007's Avatar
FB007
Your an engineer? Which railroad?
Old Dec 19, 2009 | 10:08 AM
  #125
Mike Ward's Avatar
Mike Ward
Not unarmed, uninformed or better yet- misinformed. Big difference. If you're going to stand up in public and shout that 'the sky is falling', best be prepared for those that will challenge that position. The greenpeacer in the video got what she deserved, as did the group he labelled as the '**** youth' who disrupted the proceedings.
Old Dec 19, 2009 | 10:26 AM
  #126
noonie's Avatar
noonie
Golden
There was another very long thread about this a while ago and I used a gauge to measure various conditions.
One result I didn't make too clear:
With the pcv valve disconnected and the guage hooked to the dipstick tube there was pressure recorded AND the lower seals both front and back started leaking. They did not leak before.
You should be able to find the complete thread from this too, with pics showing a slight vacuum under normal conditions with the pcv connected.
You can draw your own conclusions from some real data.
Originally Posted by noonie
Here’s some more info to mull over.
Had a little time to get some reading on the road today. Traffic was pretty heavy, so I didn’t get a lot.
I connected my “lower than atmospheric pressure gauge” (because Z-man and FB007 contend vacuum does not exist) the same as before, to the oem passenger valve cover breather tube.
I taped the gauge over the shadowband, so it’s not as clear as should be with the bright Florida sun behind it.
At startup and idle I got the same reading of 6”
After the engine got to full temp (180°) it went up to 7”
At 2000 rpm steady cruise it went back to 5”
At 2500 rpm steady cruise it stayed at 5”
At 3000 rpm steady cruise it stayed at 5”
At 3500 rpm steady cruise it dropped to 4.5”
At 4000 rpm steady cruise it stayed at 4”
Traffic wouldn’t let me cruise at any higher rpm
Half throttle acceleration thru 1st, 2nd and into 3rd stayed at 4”
Full throttle acceleration brought it to .5# pressure.
Thru all of the cruising rpm’s the needle stayed pretty steady.
At WOT acceleration, thru the gears, there was a lag of 3 or 4 seconds to reach pressure.
Old Dec 19, 2009 | 10:49 AM
  #127
...Roger...'s Avatar
...Roger...
Dang you don't have to get so mad , I know I'm not the sharpest tool in the shed but I just ask a couple questions so I can make a decision on what I feel is best for me.
If you say the PCV is costing me 50 HP then I'm tossing the damn thing and not worrying about the contaminants.
If you say its a couple HP then I think the trade off is worth it and I'll keep it.
Old Dec 19, 2009 | 11:07 AM
  #128
73StreetRace's Avatar
73StreetRace
I removed the PCV valve one year ago, mainly because the engine was idling better without it and the spark plugs were cleaner.
But I didn't notice ANY difference in power. I don't say there is no difference, but in my case it was not significant.
Old Dec 19, 2009 | 11:34 AM
  #129
leetownreb's Avatar
leetownreb
Let's face it, there's a reason the PCV sucks, as does the rest of the intake crap.
Old Dec 19, 2009 | 11:41 AM
  #130
Matt Gruber's Avatar
Matt Gruber
Golden
great info! seems a new/stock engine can indeed pull enough air thru that tiny valve,
and a high power or worn engine overwhelms the valve, like on my 67 289. Connecting to the air cleaner base does vacuum the gases out of the crankcase, but in a higher volume than the pcv valve. i actually learned something
Old Dec 19, 2009 | 11:42 AM
  #131
FB007's Avatar
FB007
1) At idle, a PCV is at it's strongest use. How much HP is required for idle?10-20HP?
2)At cruise, a PCV is also at peak level. How much HP is required for cruise? 35-45HP?
3)At WOT, a pcv does zero. Thusly, at WOT, a pcv has no impact.
4)Even race cars use vauum pumps/dry sump set ups due to negative pressure adding performance. What draws less HP? A mechanical pump or a stupid metering valve?
5) Blowby is unburned gasses. Reintroducing them to the intake side can do little harm. It originated there in the first place.
6) Every English car manufacturer goes bankrupt.
Old Dec 19, 2009 | 01:27 PM
  #132
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Go out slinging insults. Great form.
Old Dec 19, 2009 | 02:38 PM
  #133
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I can accept that a PCV is fine on many an application, and I'm not going to attempt to talk anyone who thnks they're better off with one into removing it. However, the thing is they aren't necessarily the best solution for everything under the sun, and, as does 73StreetRace, I have some well founded reasons of my own (which have nothing to do with power) for not planning one for the particular hi-po engine I'm currently on. I submit that both sides should get over themselves...
Old Dec 19, 2009 | 03:01 PM
  #134
DaJesterMan's Avatar
DaJesterMan
i second the motion...
Old Dec 19, 2009 | 04:08 PM
  #135
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Dec 19, 2009 | 04:14 PM
  #136
Mike Ward's Avatar
Mike Ward
I was just out in the garage and my car is in a snit cause you called it's metering valve stupid. Thanks for that.
Old Dec 19, 2009 | 04:19 PM
  #137
midyearvette's Avatar
midyearvette
whatever horsepower your pcv is costing you is minimal at best especially on a street application, if your ring seal is good....the statement that a pcv is burning un burned gasses is un true as it provides a route for crankcase fumes that are not really that combustible unless contaminated by an over rich mixture and a bad ring seal with fuel diluted oil. therefore these fumes are ingested by the mill and actually take the place of some raw metered fuel as a mixture from the carb in the intake manifold or plenum. by displacing some of this volume with crank fumes instead of metered fuel, yes there is some slight hp loss. the statement that a pcv is only effective under high vacuum conditions is also un true as at wot on a marginally healthy mill, the valve is actually overcome by blowby and the tube then is another breather for the crankcase and blowby is actually entering the plenum and sucked in the mill mixing with metered fuel instead of the atmosphere as the usual second breather is going to the atmosphere. it all depends on engine health as to how much the pcv is hurting performance. usually a comp. engine is not pcv equipped and blowby escapes through "breathers" to the atmosphere and does not contaminate the fuel mixture but unless these fumes (blowby) are captured or released in some other way, they make for a messy situation. pcv was introduced as a smog device and they make for cleaner roadways and the atmosphere we all breathe. if a mill in poor condition with lots of blowby, the pcv is it's enemy as it will easily foul plugs but somewhat save the atmosphere. a mill in good shape will not be affected in a negative way by running a pcv but tuning is generally easier on a non pcv mill, mainly idle mixture in different temperature situations.....
p.s.....to equate a mechanical vacuum crankcase pump to a pcv valve is ludicrous.....you are comparing an outside vacuum source that evacuates blowby to one that is made by the mill and plumbed to the plenum....
To PCV valve,can I remove?
Old Dec 19, 2009 | 04:42 PM
  #138
FB007's Avatar
FB007
1) A vacuum pump lowers the crankcase pressure.
2) A PCV lowers the crankcase pressure.
3) A road draft tube, under high speed, moderately lowers the crankcase pressure due to the venturi effect.
4) A header venturi system lowers the crankcase pressure.
  #139
FB007's Avatar
FB007
Old Dec 19, 2009 | 04:43 PM
  #140
leetownreb's Avatar
leetownreb
Succinctly stated!
