70 Auto trans X member
Then when I replace the cross member is there any torque spec on the cross member bolts?
Any suggestions will be appreciated.
Thanks for any information.
Best of luck
Easy Mike, Thanks for comfirming this info. I was going to at least place a jack to slightly lift the rear of the tranny then place a jack stand under the very back of the trans or as far forward on the drive shaft as possible then shim it to the height of the jack for the best support. I may or may not have the trans pan off at the same time and dont want to get dust or dirt anywhere near the open transmission.
So when I replace the cross member do I just tighten up all the bolt or are there torque setting for the crossmember bolts. I havent been able to find any yet.
Roco 71, Thanks for the crossmember tip and yes sir the exhaust has been removed. In fact I just installed new side pipes a couple of weeks ago.
Just trying to pre plan pulling this cross member job cause I have a master cylinder repair first to deal with.
Thanks again guys and have a Merry Christmas.
Good luck
Good luck
As a matter of fact I changed my plan of attack and went ahead and droped the cross member to get it cleaned and preped so I can take advantage of the 50 to 55 degree weather were going to have tomorrow so I can get it primed and painted outside and not in my garage.
I didnt check this thread till tonight and now wish I had cause I did exactly what you said to look out for and that was the brake cable. Must admit it made me laugh.
Thanks.
I must admit my frame is in excellent shape for a 40 year old car. In fact the paint on this cross member looked and acted like the old original asphalt paint.
Crossmember still on the car.
Got it off the car.
Cleaned it up then took it to the car wash to wash inside the crossmember.
Buffed it down with some 400 grit sand paper and primed.
Then got R painted.
Now I have clean all around the transmission and side rails and buff and paint the side rails over this weekend.
Thanks for the suggestions.
Thank You Sir,
I have jacked myself in terms of time cause I didnt order the transmission mount in time & with the christmas mail build up I'll be very lucky if it show's up by monday.
Currently buffing down the passenger side side rail and will get it primed here shortly then tomorrow will wash and detail the bottom of the body. I need to figure how to attack the grime build up on and around the transmission and trans tunnel. Maybe I'll have the driver side side rail finished by sunday night if I'm lucky.
Thanks for the suggestion. I have the foam piece that I'll install and the big foil insulated tunnel deflector is still in and in pretty good shape concidering it's the original. You can see a small piece of it in the first picture I sent. Thats the area where I'm not to sure on how to clean it other then my hand full of different brushes and degreasers to reach up there to remove the small amount of grime build up. The back end of the deflector is a little loose and hangs down a bit and I need to figure out how it keep it up tight to the body. I noticed the crimping clamp is what I'll call it that holds the deflector to the body is out and will fix that. I'm afraid if I remove what I have now which is not in to bad of shape & try to install a new deflestor I'm going to wish I hadnt.
Once I get the car finished I'll enjoy it for a few years then do a proper complete body off and that was my thinking from the beginning but can assure you I'll never do a body on restoration again cause I've doubled up on all the work I've had to do under this car.
Crossmember looks great. In fact, it looked great before you took it down to paint it!
Now, as sure as the snow is flying today (mid Atlantic area), somebody will criticize you for "rattle canning" the crossmember. And, should you ever sell the car, prospective buyers will suspect that you painted it to hide rust, blah, blah.......
Rickman
Rickman
Thanks ok they can blah, blah, blah all they want. Truth is I'm going with a rattle can in this point in time due to the fact that this is my first restoration of any kind and felt it best to do a body on so not to get in over my head with lack of experience. Now having done most of the engine bay, engine, front suspension, radiator, & complete AC & heater system and working my way back to the rear end, I'm wishing I had gone with a body off project.
So what I plan on doing is finishing this frame and rear end section to the best of my ability then when the car is finished I'll drive it for a few years then do a body off.
Like you mention before the pictures tells the truth and the pre condition of this frame before I painted it.
Hopefully when I'm done with the frame it will take a very skilled eye to tell I did it all with the ole dredded rattle can, but then I will encourage any one to look cause I have put a lot of detail in this car doing it this way and the next car which is my vert will be a body off project for sure.
Thank again and Merry Christmas.
Excellent idea to document w pics everything underneath. Keep up the great work.
I guess w the 2' of snow
we received in MD today the Corvette driving season is officially over. I will not drive my Vettes now due to the SALT placed on the roads. C'mon Spring!!Rickman
