Leaf Spring - Fiberglass
Old Dec 19, 2009 | 09:24 AM
RadicalPursuit's Avatar
RadicalPursuit
Default Leaf Spring - Fiberglass
Wanted to know if anyone using a fiberglass rear leaf spring had any problems/issues with positive rear camber? Mine is a TRW 330 lb. I have have a significant positive rear camber, to much to adjust with the aftermarket strut rods.
Old Dec 19, 2009 | 10:08 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Make sure you move the car (roll back and forth) after dropping it back on the ground from having it in the air. They always look way out till you move the car.
Old Dec 19, 2009 | 10:10 AM
hugie82's Avatar
hugie82
I have over 100k on mine w/ no problem. You need to check your ride height. If that is OK and your strut rods are maxed, then the yokes going into your rear are worn (shorten due too wear)
Old Dec 19, 2009 | 10:54 AM
Mike Ward's Avatar
Mike Ward
The type of spring has no influence on wheel camber.
Old Dec 20, 2009 | 01:57 AM
RadicalPursuit
Default Leaf Spring
I'll check the ride height. I've replaced the right rear half shaft because of damage caused by a failed U joint.
The problem is noticable, especially with the car on the ground. I didn't notice the problem until after replacing the transmission, and right rear half shaft.
Old Dec 20, 2009 | 02:07 AM
RadicalPursuit
Default Ride Height
What should the ride height be?
To Leaf Spring - Fiberglass
