I'm looking at getting a replacement carburetor rather than rebuilding the Edelbrock Performer 600CFM I have on right now. This Summit M08600VS carb is only $259 and based off the Holley 4010 with the design flaws from the original 4010 worked out. Summit states that this carb is in fact manufactured by Holley.
Does anyone have experience with this carb? At only $259 and free shipping, this looks like a great deal.
This will be going on a L48 350 that is bored .030 over, with 64cc Vortec heads and a performer RPM intake. Compression is 9.78 : 1.
If your engine can't accept more than 600 cfm airflow, then it should be as good as any other carb....if it is adjusted to your engine properly. {Quadra-Jets, of course, can provide any airflow up to 750 cfm.}
I can't really help you there, but I'm also thinking about purchasing this carb either for the Vette or the Camaro, later on in the future.I have the Holley 670 Street Avenger on the Camaro, but a lot of guys, including me, have idle problems with these and you need to change the jets and do some other things to it in order to get the idle right.
That is a great carb,ive run them for years,quick response,great power,easy to tune,no blowing power valves,only 2 piece carb no gaskets to leak like others.Holley use to produce this carb and sold the rights to summit racing and summit made it even better.Maintance free carb
