Does '74 454 Like to Rev?
The car did not come with the original qjet, so I purchased a '73 qjet, 7043200 (pretty close to '74 qjet but actually 6% more jet area at WOT), rebuilt it per the Lars papers and installed it. The performance was good, and I like the sound of the vacuum secondaries, but they are A LOT slower to come on then the mechanical secondaries of the Holley. I am going to adjust the top plate spring to see if I can get them to open quicker, but from this and other threads I do not think it will make a difference over the Holley.
Floor the throttle at 2500 in first, and the tires chirp/spin (265/70/15 - M21 - 3.36 diff), which is actually kind of dangerous if you are not paying attention going around corners. Floor the throttle at 2500 in second and the tires chirp. The qjet was not even close to spinning/chirping the tires.
Another thread I was following was all about the great mpg of the 6210. I do not drive the car enough to care about mileage. I got crappy mileage with the qjet (12mpg), but besides flogging the car every drive I spent so much time tuning it in the driveway that I never got a fair read.
I have not run a full tank on the Holley yet. Based on all the WOT runs I have been making I am guessing it is going to be crappy too.
When you say "The factory Q-jet will spank it performance wise", have you run the Holley as well and had bad results? I have not found very many who have tested both on this forum, so any results would be appreciated.
Your track comments are on the money. I am not interested in getting that last half second off the quarter mile, but it would be nice to have some quantitative evidence comparing the two cars. I am pretty sure I am running at worst in the low 14s, but I am tuned better than stock with .045 plug gaps and 52 degrees of total advance. Car runs great.
Another local forum member posted a bunch of info from dyno runs he did. I sent him a PM to find out where and how much. I think that would be the most accurate way to get the data.
It is interesting you say "ease your mind". That is exactly what this is about, and I really need to let some of this go and start focusing on other areas of the car. In particular the AC is not working, and that is something that will keep me from driving the car in about 5 months.
I am now happy with how the car runs, but I do plan to keep an eye out for a 6211. If one comes by reasonable enough, I will give it a try and definately report on the results.
The qjet is not out of the picture yet either. I am going to try some different adjustments on the secondary top plates to see what the impact is. I am thinking if I adjust the springs to the point a light breeze opens them up I may be able to get that mechanical secondary feeling. If something interesting comes from the experiment I will certainly report on that too.
.., but besides flogging the car every drive I spent so much time tuning it in the driveway that I never got a fair read.... I am not interested in getting that last half second off the quarter mile, but it would be nice to have some quantitative evidence comparing the two cars........
That's another tuning trick u will find in Dave Roes book and the Ruggles Qjet "How To" book but i'm not sure how well he explains it. I think that pull off has a designed leak and is tricky to measure.
Just another item to look at when tuning a Qjet.
The Qjet learning curve is much steeper than other carbs.
Hope this helps,
cardo0
You can quicken up the secondaries in two ways: Easiest is to slightly loosen the secondary airvalve spring. 3/4 turn windup is a good, safe setting, but many large engines can take it as loose as 1/2 turn.
If the airvalve is still slow, you can drill out the restrictor hole in the choke pulloff. It's good to have a couple of spare ones on hand if you do this. This will relax the pulloff more quickly. Enlarge the hole about .002" at a time, since a slight change makes a significant change in the pulloff's response. Also, when the airvalve opens quicker, you get less of a "pump shot" from the secondary pullover circuit, which can contribute to a stumble.
Lars
Mandingo, I say the Q-jet will be better for you performance wise because I believe your engine will use the extra cfm the Q-jet has over the Holley. A smaller cfm carb will feel more responsive around town but there comes a point in the distance you are racing that it does not make as much power if it can't flow adequate air for the motor. You've only got two choices in carbs if you stick with your factory intake. You do not want to use an adapter plate! And of those two choices for your motor the Q-jet is best. I think that Q-jet can deliver the same tire spinning performance as the Holley. You've got Lars attention he can definitely help work this out.
Track time is cheaper than dyno time and slightly funner. Since your motor is so close to stock you can be sure your jetting is pretty close. Find out how fast it really is with that Holley then try your retuned Q-jet. The one that gives you the best MPH is the one you keep.
I was very happy with the Q-jet that came on my car but was not happy with my intake. That stock intake is a beast! Very heavy. So when my car went on a diet it lost the intake in favor of an aluminum square flange. I replaced the Q-jet with a Holley 780cfm vacuum secondary. Really no change in performance. Due to choke clearance issues I have since replaced that carb with a chokeless Holley HP 750cfm vacuum sec. This is a great carb and is definitely the best performer of the bunch. Here in Ohio, I miss the easy starting of the Q-jet though.
Properly set up/jetted/tuned, I can tell no difference at all in performance between a 750 cfm Q-Jet and 750 Holley/BG carbs. If you correctly tune the vacuum secondary on a vac sec Holley/BG (get it to open quick enough), the vacuum carb will perform very similar to the mechanical secondary carb ("double pumper") with the exception that the secondary side is not as easily tunable due to the metering plate on a 4160. Bigger carbs (I've run carbs up to 1050 cfm on my 357 small block) don't neccessarily produce more power above a certain size, yet they can be set up and tuned to run just fine on the small engine with no stumbles or mixture problems. I can tell the difference in performance between a 750 carb and anything smaller -top end power does drop off with the smaller carbs. I have found no drivability or loss of low-end by running 750+ carbs, but you cannot slam a big mechanical sec carb into the secondaries at low rpm without the car falling on its face - you have to use good "racecar driving" technique with big mechanical carbs.
Bottom line: Run the carb you are most comfortable tuning. Within a given cfm range, any of the carbs will run the same if they're tuned correctly. Big disadvantage with the Q-Jets now is the complete lack of parts availability other than jets and some early-series (4MV) primary rods - unless you have a Q-Jet parts stash, you can't tune a Q-Jet properly.
Lars
Right now I have the qjet set at 3/4 turn past where the spring hits the tang. Going to 1/2 a turn past does not feel much different (on the bench, not on the car). Setting it when the spring hits the tang lets the plates hang partially open, so I am assuming that is not an option.
I will try the 1/2 inch setting and see how that runs.
1/4 past also keeps the plates closed so I was going to see what that did. All I am risking is a secondary tip-in stumble, correct? As long as the adjustment will not cause gas to be sucked into the engine at idle, or something else bad, I thought I would try that.
I am worried about the abbreviated "pump shot". For all the talk about how the Holley gets better mileage, looking down into the carb when you hit the throttle it looks like it is flooding the engine with gas. I think that is a big part of the response differences in the carbs.
My last concern on the qjet is the choke pull-off. I do not want to risk screwing up the whole air-valve shaft by drilling out the restrictor hole, but how fast should the pull-off be relaxing? I put a new one on as part of the rebuild and it takes two seconds from fully in to full out.
That time alone would make it less responsive than the Holley.
Thanks for the help.
I'm so glad to see you chime in!
Too bad we don't both live near the same track! It would be great racing!
650 cfm 6210 challenges the 750-800cfm qjet
mandingo
don't confuse carb noise with HP. My 283 w/6210 would go 121 mph WOT WAAAAAAA Then i'd let up until the back barrels closed, very quiet and maintained 121 mph. Front only 1/2 open. Cool Sound made it sound faster, but it wasn't.
took a peak at a 72 454 auto that has sat for 10 years in a garage or shed really and hasn't been started, dame owner25years It has the original motor and transmission...... sitting on 4 rotted flat tires , dead apint and rattle can sprayed interior ..... home to mice . I think it might make a nice car with ALOT of TLC.
I like 72 and up , the VIN IDs the car.
