71 Vette - no "high" on blower fan issues
Old Dec 19, 2009 | 11:59 PM
fast69cam's Avatar
fast69cam
Default 71 Vette - no "high" on blower fan issues
I have a 71 Vette (350 / 270hp, with a/c) that I have replaced the blower fan switch, the blower motor cutout relay, the main control in console, new engine harness, a/c harness, front wiring harness, but I still have no "high" speed on the blower fan.
I bought another piece, the blower motor resistor ( see this link for picture -
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={47db8b56-6c89-413f-9427-cbe240fb5251}&pname=63-79+Blower+Motor+Resistor&Referer=QUICK_S EARCH&Alias=1971%20blower%20relay&ptct=B S-SR&CTitle=&
but I cannot seem to find where this part actually goes. Can someone please let me know what else to check or what my problem may be ?
Thanks in advance...
Ronnie
Old Dec 20, 2009 | 12:30 AM
71coupe454's Avatar
71coupe454
I have a wiring diagram if it will help you. That part is what you need to fix the blower.
Old Dec 20, 2009 | 12:41 AM
fast69cam's Avatar
fast69cam
Default 71 fan motor no "high"
Did you look at the part I had in the posting ? If so, where does it go ? It is not the relay on top of the air box, I cannot figure out where it goes... I have a wiring diagram but it does not tell where the part is located. Let me know once you have looked at it. Thank you very much !!
Old Dec 20, 2009 | 12:59 AM
CCrane65's Avatar
CCrane65
Ok, I'm not being a smart a$$ here but did you check the 30 amp fuse on the horn relay? That is specifically for the high speed blower operation.
cc
Old Dec 20, 2009 | 01:06 AM
fast69cam's Avatar
fast69cam
Default 71 fan motor not on high
cc
.. absolutely no offense taken... I can check it again but it was brand new - part of the new wiring harness I installed. I put a new fuse in it when I put it in. I did not replace the horn relay - could this be the issue ?
Old Dec 20, 2009 | 01:40 AM
CCrane65's Avatar
CCrane65
I doubt it. As long as the post the fuse wire is connected to is hot that's all the relay does for the blower. And if your horn works then the blower should too.
If the fuse is good then it is likely the resistor in the top of the air box as mentioned previously.
cc
Old Dec 20, 2009 | 09:01 AM
7T1vette's Avatar
7T1vette
If there's a short in the wiring for that "Hi speed" blower fuse, a 'new' one will still blow immediately. Remove the fuse and check for continuity. If 'bad', find the short in the wiring and repair it. If 'good', you have an open circuit somewhere in the wiring or no power (+12v) going to the fuse.
Old Dec 20, 2009 | 09:35 AM
mds3013's Avatar
mds3013
If you are still looking for where it is installed here is a picture of my '77. I do not know if yours is in same location but all blower resistors will be located in the "duct" where air flow will cool the coils. mds...
Old Dec 20, 2009 | 03:06 PM
...Roger...'s Avatar
...Roger...
Is the blue wire going to the relay getting 12 volts when the switch is in the high position "AND" is the relay grounded ?
edit-the high blow bypasses the resistors
Old Dec 20, 2009 | 03:58 PM
CCrane65's Avatar
CCrane65
You do have 4 wires on the blower relay right? One black, one blue, one orange (12 gauge) and one purple (12 gauge).
The wires are connected in the following order as you are looking at the bottom of the relay:
Black
Purple
Blue Orange
You should have the bottom three wires in a single connector but mine was missing so I offer this information just in case.
cc
Old Dec 20, 2009 | 05:16 PM
...Roger...
Black
Purple
Blue Orange
cc
But make sure the other end of the black wire is grounded through the blower ground.
wiper,relay,blower all ground together through the black at the starter.
Old Dec 20, 2009 | 06:50 PM
oldsarge's Avatar
oldsarge
the resistor is under your dash behind your radio area, screwed into the heater box ductwork.
Peterbuilt's Avatar
Peterbuilt
My plug that goes to the (relay) in the top of the picture, is melted. Where can I get a new one?
Old Dec 20, 2009 | 08:09 PM
...Roger...
http://www.autozone.com/autozone/cat...andName=Dorman
Old Dec 20, 2009 | 09:54 PM
Peterbuilt's Avatar
Peterbuilt
Thanks, that was to easy, hope fast69cam's problem can be fixed so easy!
Old Dec 21, 2009 | 01:36 AM
fast69cam's Avatar
fast69cam
cc
OK, I've checked and the fuse is good AND I have positive current coming from the orange wire coming from the horn relay. Is there any thing else I can check ?
Old Dec 21, 2009 | 02:21 AM
fast69cam's Avatar
fast69cam
If this resistor is bad, will it effect the "high" operation of the fan blower motor ?
To 71 Vette - no "high" on blower fan issues
Old Dec 21, 2009 | 06:39 AM
7T1vette's Avatar
7T1vette
No. The resistor pack is not in the circuit when the blower is on "High" speed. If there is power to the 'input' side of that fuse, that means the blower switch and wiring up to the fuse are good. Your problem must be between the fuse and the blower motor. That leaves just the wiring between them and the blower relay. My bet is on the relay.
Old Dec 21, 2009 | 09:47 AM
...Roger...
Does the relay click ?
Old Dec 21, 2009 | 10:48 AM
fast69cam's Avatar
fast69cam
Is there any way to test the relay ? The relay is new, along with all of the wiring, new engine harness and a/c harness.
