Took a peek under the car rear end and saw the rear leaf spring is nearly flat. Is that a sign that i need a new one? I think it's the original spring, if that helps any.
Tell you the truth, I don't know/remember the arch of the spring under loading...
if the car sits lo, replace the spring, assuming you have stock bolts from spring to t-arms....if someone replaced them with longer bolts, they could be adjusted toward the ends, hense riding lo in the rear....
if you need a spring, get a plastic one, with new shock all around...far better ride and controll....far better...in fact it's worth doing just no matter the contition of the metal spring...
