Cat bypass
Old Dec 26, 2009 | 07:26 PM
81pilot's Avatar
81pilot
Default Cat bypass
When I bought my 81 the Cat had already been removed, It has a bolt in bypass of substantial size where the cat was.....my question is, should I replace that section with true duals or will it provide enough scavenging to leave on? I know the exhaust scaveging is the reason for installing an "X" pipe, I could put an "X" in its place....Thanks, Jeff
Old Dec 26, 2009 | 07:29 PM
forvicjr's Avatar
forvicjr
If engines stock should be ok.IMO depends on whether you want to or not and if you plan on significant changes fom a stock motor if thats what you got.
