Hooker install issue
Old Dec 27, 2009 | 09:01 AM
Crimson Ghost's Avatar
Crimson Ghost
Default Hooker install issue
I picked up a set of s/c headers and pipes from Summit. The driver side header flange does not site flush on the head and the bolts will not pull it in without stripping.
If I were to lay flange on the ground it would rock longwise rather than set all four ports flush on the flat surface. The passenger side appears fine. I had to ding one of the down pipes in need of a ¼ clearance – but I suspect had the flange sat properly I would not have had to do this. Is there anything I can do?
Old Dec 27, 2009 | 09:42 AM
Duke94's Avatar
Duke94
Send them back, they should be flat across the sealing surface. Summit is pretty good about taking stuff back.
Gary
Old Dec 27, 2009 | 10:04 AM
Roco71's Avatar
Roco71
Old Dec 27, 2009 | 10:09 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
You paid for a quality built product by Hooker, send them back.
Old Dec 28, 2009 | 07:57 AM
Crimson Ghost
I called Summit this morning – excellent customer service. I told them I dinged one of the pipes to get around the steering box (probably due to the warped flange) and they are still taking them back. I’ll get the new ones in a few days – I asked if someone could put a straight edge on the flange prior to shipping, they said “absolutely”….not sure if someone will or not --
Old Dec 29, 2009 | 11:54 AM
yellow94coupe's Avatar
yellow94coupe
I had to ding mine to go past the steering box but it still fit fine at the flange. Glad to hear you are getting a new set.
Old Dec 29, 2009 | 11:59 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Here"s what I dont understand about these Hooker headers. All they(hooker)has to do is shorten the pipes at the left head flange by 1/4-1/2 inch then you will have adequet clearance of the steering box
Is it that hard to properly make a part for a car thats been around for 30+ years??
Old Dec 30, 2009 | 07:44 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I've got a set of hookers. They bolted one perfectly - no dings required.
Old Dec 30, 2009 | 09:05 AM
SteveG75's Avatar
SteveG75
My Hookers fit fine. No dings. If the pipes were shortened, I would be unable to get the plugs in and out (especially number 1). The product is just fine.
Old Dec 30, 2009 | 11:08 AM
drsvette's Avatar
drsvette
some of my friends and i have cut a straight line through the flange to alleviate flange warpage issues and also it has helped to extend gasket life by creating a tighter seal by elimenating the vibration issues.
To Hooker install issue
