1979 Throttle cable.
Old Dec 28, 2009 | 11:39 AM
michalbugno2006's Avatar
michalbugno2006
Default 1979 Throttle cable.
I just installed the bracket and throttle cable on my new carb (demon). Now the gas pedal is half way down in the car before the cable pulls the linkage on the carb. Is there any way to shorten this cable?
Old Dec 28, 2009 | 11:57 AM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Is the bracket right for the carburetor? You can also relocate the anchor point of the cable sheath by bending the bracket if desired. Also be sure that the attachment point on the carb's throttle arm is the same distance from the center of the shaft as it was with the stock carb.
__________________
1978 Corvette
406 SBC AFR heads Lunati roller Quadrajet TH-350 3.08
11.59 sec / 118.9 mph 1/4 mile
Old Dec 28, 2009 | 04:09 PM
michalbugno2006
I know it's not the right bracket but what bracket could I use? It's a speed demon. There is about an inch of slack in the line, the line also bends before the little square.
Old Dec 28, 2009 | 07:17 PM
michalbugno2006
Well I found the bracket I would need. I'm also thinking about changing the cable to the lokar type. Is this difficult? I just put the dash back in today
Old Dec 28, 2009 | 07:24 PM
WhiteC3's Avatar
WhiteC3
The lokar type cables are great! I've used them before and really like them.
To 1979 Throttle cable.
