I'd like some feedback on converting to roller rockers after having stamped steel and ajusting those for years. Hopefully someone has done this. This is on a bbc 454"
Method used is exh opening - adjust intake --- intake closing - adjust exh
- When you install and adjust a stamped steel rocker and interferance nuts - twisting the pushrod until resistance is felt and turning 1/2 turn past zero lash, the pushrod feels pretty firm and takes a fair amount of pressure to turn it in the lifer. The rocker is also pretty firm on the stud. So far so good.
- Now I am trying to install Summit alum roller rockers, same ratio of 1.7:1.
- When you get to zero lash (which can be done with finger tension - no wrench needed) with the pushrod meeting the same resistance feel as with stamped steel rockers, I turn the trunion 1/2 turn more. This is where I am goosey as the trunion turns super easy and the pushrod just seems to be not as tight as the stamped steel rocker.
Is there something that needs to be done with alum roller rockers as far as turns past zero lash or are they just so much more a precision piece that what I am feeling is normal?
If a lifter has bled off, will that change the zero lash point by the plunger being further into the lifer body?
no......the preload spring will keep the plunger at the top of the lifter itself, you will just have a lot less resistance when tightening the poly lock because there is no oil for a cushion( brace)...keep doing what you are doing and you will be fine.....
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
When I used to build hydraulic motors I would adjust the valves the first time with the intake off so I can get my hand on the pushrod easier. I move it up and down, when no more movement 0 lash.
You said it yourself, stock rocker nuts are interference fit that is why they are harder to turn down. I would go 3/4 of a turn with the polylocks sometimes the cheaper ( not saying you have them ) polylocks will pull up on the nut when you tighten the inside allen keeper screw, therefore you won't have the 3/4 turn anymore, it will be more like 1/2 turn. Just my 2c
