spark plug wire looms
Old Dec 29, 2009 | 11:29 AM
1yy07's Avatar
1yy07
Default spark plug wire looms
would somebody please post picks of spark plug loom set up w vortec style valve covers w hooker headers
Old Dec 30, 2009 | 11:21 AM
MN80Vette's Avatar
MN80Vette
This isn't a very good picture of the wire loom I used to have, but they are anodized blue and mount on the valve cover:
Here are the ball milled wire looms I now:
These are mounted on the block, not the valve covers and match the ball milled ac cover I have now too:
Old Dec 30, 2009 | 07:43 PM
marz's Avatar
marz
Here is one from R&M
Old Dec 30, 2009 | 11:55 PM
MN80Vette's Avatar
MN80Vette
There are a number of wire looms with this design available. I had a set but didn't like covering the valve covers. That's why I switched to block-mounted wire looms. The other choice I tried was the inviditual plastic looms that attached to 3 of 4 valve cover bolts on each side.
What look do you want?
Old Dec 31, 2009 | 12:14 AM
cherrybombc3's Avatar
cherrybombc3
[IMG][/IMG]
DART VORTECH HEADS & HOOKER HEADERS W/ BILLET SPECIALTY'S WIRE LOOMS
Old Dec 31, 2009 | 01:42 AM
MN80Vette's Avatar
MN80Vette
Originally Posted by cherrybombc3
[IMG][/IMG]
Those are the same wire looms I have. What I like about them is that they don't advertise the fact that Vortec heads have center bolts on the valve covers unlike the rest of the SBC world.
HOWEVER, if you like the wire looms mounted on the Vortec center bolts, then go for it. Check flea bay for center bolt wire looms to see what your options are and then shop around. Maybe a C3 Forum sponsor or two have them too and will chime in with their offerings.
Old Dec 31, 2009 | 08:24 AM
marz's Avatar
marz
I like this cleaner look myself. Good luck.
Old Dec 31, 2009 | 08:26 AM
marz's Avatar
marz
Good looking motor. Where did you get the temp gauge to your water pump?
Thanks.
Old Dec 31, 2009 | 10:51 AM
cherrybombc3
Thanks.
Thanks for the compliment, the gage was found at Jegs.
http://www.jegs.com/i/JEGS/555/41000/10002/-1
To spark plug wire looms
