Checking "Run-Out"...
Old Dec 29, 2009 | 01:37 PM
Apocolips's Avatar
Apocolips
Default Checking "Run-Out"...
I know that it has been discussed before but I can’t seem to find the exact thread. I keep hearing form folks to “be sure the run-out” is correct when installing new rear rotors. How do you check the run-out, and what should it be? If shims are required, where do I get them?
Old Dec 29, 2009 | 02:23 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
http://forums.corvetteforum.com/c3-t...nout-help.html
The thread above will provide the information and picture of the process.
The shims that I prefer are Brake Align P# BA801-XX. The XX is the thickness needed. There is a video on how to install. (www.brakealign.com). These are a bit expensive but available through the local GM parts distributor. My runout rig is pretty simple. It is just a dial indicator held to the spindle arm with a Vise Grip.
Old Dec 29, 2009 | 02:24 PM
Manuel Azevedo's Avatar
Manuel Azevedo
The rotor needs to trun true to the axle flange with no wobbleing. Most say to simm the rotor to run a bit truer. They would go on the back side of the rotor between it and the axle flange. You can buy shimm stock at most older type auto parts houses. But this is not the best thing to do. You need for the rotor to be cut properly in the first place. And if the mechanic doing the cutting knows what he is doing and using a good machine will be able to cut the rotors without that wobble.
Old Dec 29, 2009 | 02:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My rotor is fine, my hub wobbles slightly, new bearings just got a slight wobble over the years I guess. Shimming and o ringed calipers seems to have solved the problem
Old Dec 29, 2009 | 04:00 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
When GM originally cut the rotors they did it after the rotor was riveted to the outer axle. The stock axle face was not perfectly perpendicular to the centerline of the axle. So when you drill out the rivets and turn the rotor or install new it really doesn't matter who turns it or how good they are your rotor will likely have a runout problem. Shimming is the only solution. I found the new Tom's axles I have now are better made and with new rotors runout was almost perfect without shims. I would guess that other manufacturers aftermarket axles would have better than original tolerances due to modern machining methods.
To Checking "Run-Out"...
