Cam Choice - Need help
Old Dec 30, 2009 | 03:00 PM
c31980's Avatar
c31980
Default Cam Choice - Need help
found those 3 cam but dont know what will work best with my setup :
-L48-freshly rebuilted engine overbore .020 flattop speed pro pistons
with 4 valve relive
-edelbrock performer rpm heads 64cc 2.02/1.60/180
-edelbrock intake 2101
-hooker headers
-700r4 tranny
-rear gear ratio stock 3.08
Xtreme 262h
Operating Range: 1300-5600 RPM
Duration Advertised: 262° Intake / 270° Exhaust
Duration @ .050'' Lift: 218° Intake / 224° Exhaust
Valve Lift w/1.5 Rockers: .462'' Intake / .469'' Exhaust
Lobe Separation Angle: 110°
Xtreme 4x4 254H
Operating Range: 1000-5200 RPM
Duration Advertised: 254° Intake / 262° Exhaust
Duration @ .050'' Lift: 210° Intake / 218° Exhaust
Valve Lift w/1.5 Rockers: .447'' Intake / .462'' Exhaust
Lobe Separation Angle: 111°
Xtreme 4x4 262H
1300-5600 RPM
Duration @ .050'' Lift: 218° Intake / 226° Exhaust
Valve Lift w/1.5 Rockers: .462'' Intake / .480'' Exhaust
Appreciate any feedback or recommendation
Old Dec 30, 2009 | 05:42 PM
gkull's Avatar
gkull
Crane 272 for the cam.
Then you need a 3.90 rear gear to make the most out of your 700R4 OD. Does your 700 have the mods for 4th gear only lockup and the ability to use Wide Open Throttle in 4th gear without it doing a auto down shift? It is kind of fun to rap the speedometer around past 140 mph. mark.
Old Dec 30, 2009 | 06:50 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
With your higher compression ratio, I'd go for the XE268H.
__________________
1978 Corvette
406 SBC AFR heads Lunati roller Quadrajet TH-350 3.08
11.59 sec / 118.9 mph 1/4 mile
Old Dec 31, 2009 | 03:43 AM
c31980's Avatar
c31980
thanks gkull
but ido not intend to change my gear ratio at least for the main time ,, i just need a cam
to match my setup
thanks larry ,,
but i think the XE268H has rugh idle that will affect the vac
how about the XE262h ? does anybody have any comment on that?
Old Dec 31, 2009 | 10:49 AM
gkull's Avatar
gkull
I would not even tell somebody that I didn't like to buy a pot metal Comp Cam. Look at the specs of the Crane 272 I ran it in my Vette for many years
Old Dec 31, 2009 | 11:25 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Those are all pretty mild cams. If you're going to stick with the stock torque converter and the 309s, either of the 262s should work fine.
Old Dec 31, 2009 | 11:49 AM
Taijutsu's Avatar
Taijutsu
I run the 218-224HR w/1.6RRs. I love this cam and the BB mid range it produces. It is a little soft just off idle, I have M21 w/3:55 so it is not a problem.
The best cam advice I have read is:
Do your homework and try to pick the perfect cam for you. Then buy the next smaller cam. lol
Ask yourself what are your driving habbits?
Is that the Performer or RPM intake? The performer will flow a lot less than RPM intake. The good news is that there are so many SB builds that all you have to do is pick your rpm range and your budget. JMHO
Listen to GKull and the others, they have paid for their experience!
R
Old Dec 31, 2009 | 12:31 PM
Blue79's Avatar
Blue79
Just curious -c31980 you have your location listed as Kuwait and I was wondering if you can tell us about the quality and/or octane of the fuel over there.
Old Dec 31, 2009 | 12:50 PM
c31980's Avatar
c31980
good feedback & input from all m8ts ,,,, gona review the option & make a choice
as for the crane cam i had it before the rebuilt and now i have lunati 10001
nice cam good idle but i need somthing more aggressive ,,& yes i have ther performer intake also gona keep my stock converter for the main time ( low Budget ) i drive the
car all week day & i do like smoke some rubber
thanks ,,have agood time
Old Dec 31, 2009 | 12:56 PM
c31980's Avatar
c31980
yes iam in kuwait ,, normal is 98 octine and also we have 120 octine for
new genration auto like the bmw and the mb
price : is around half $(25cent) for the normal
and half a dolar for the 120 octine
also in suadi arabia pump gas is alot cheaper
Old Dec 31, 2009 | 01:41 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
With Flat tops and 64 CC heads your cam choices are too small. With gkull or larrywalk and also with a flat tappet either a billet core or the additional tempering offered by most manufacturers.
Old Dec 31, 2009 | 11:17 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Originally Posted by c31980
thanks gkull
to match my setup
thanks larry ,,
FWIW I'm running a 268 in a 383 with similar compression/piston combo and 3.08 rear. Idle is sweet and pulls 15" vac. and the power range is exceptional.
Old Jan 1, 2010 | 05:20 AM
c31980's Avatar
c31980
63mako & dosoctaves
i think iam going to put the 268 ,,
thanks to all of u great help as usual ,,
have a good time
To Cam Choice - Need help
