carburetor internal corrosion - fuel?
Old Jan 2, 2010 | 11:43 PM
69VetteAngel's Avatar
69VetteAngel
Default carburetor internal corrosion - fuel?
Hi folks,
I have a problem with my 750 Holley vac sec carb on our 350 ci vette engine. Has anyone else experienced any problems with corrosion in the carb from the fuel? The car does sit for some time between seasons, but is always indoors in a climate controlled garage and gets regular doses of Fuel stabil..
Here is what I found when I disassembled it this time. This is the second time I have found this, and I get fuel from the same station that I get it for my 68 Dodge. I never , ever had any problems with that Holley carb. .
I just took it apart also to do some jet tuning, and it was as clean as a whistle. The only difference between the two is that the Dodge has the standard gold annode coating, while the vette had the polished silver look.
Any insight or others with the same issue would be appreciated.
Thanks and Happy New Year!!
Greg.
Old Jan 3, 2010 | 12:07 AM
cherrybombc3's Avatar
cherrybombc3
I think alot of us would like to know what caused that?? What ever it was it sure looked to be corrosive.
Old Jan 3, 2010 | 12:17 AM
WhiteC3's Avatar
WhiteC3
Yep seen that before and its from our enviromental freindly mileage killing reformulated fuel.It will absorb moisture. That fuel is a killer of aluminum alloy parts. I always go out of the way to get nonreformulated gas for winter storage.
Old Jan 3, 2010 | 12:28 AM
69VetteAngel
So, you don't think the Fuel Stabil I add protects the fuel at all from this moisture? I don't know if we have the Non-Reformulated fuel here in NY. I will ask around, but I still would like to know why this happens only on the vette. The Charger has the same fuel and no corrosion. Strange.
Thanks for letting me know,
Greg.
Old Jan 3, 2010 | 01:37 AM
WhiteC3's Avatar
WhiteC3
At some time there was fuel that contained moisture. It seem to be hit/miss kind of thing.Fuel stabil does not hurt, but it seals the fuel and if it happed to contain small amount moisture. I would like to know more but this is what I have noticed. Just my 2 cents.
Old Jan 3, 2010 | 04:31 AM
Golden's Avatar
Golden
We don't have any of your weird 'green' fuels here, the only time I've seen corrosion like that is when the fuel has got contaminated by some other corrosive chemical, it's shocking that just moisture can do that
Old Jan 3, 2010 | 05:05 AM
mrvette's Avatar
mrvette
I had problems with water/something nasty in the bottom gallon or so of my '72 vette gas tank, it upset the living hell out of engine operation, with FI on it, drove me nutz for some time...well, it was finally found when running the thing really low, and the bottom crap was finally sucked enough into the lines that it killed the engine....that is when I found the bad stuff....cleaned the tank, and that cured the problem for quite a while...
it has slowly come back over the last year or so, and so I now have had a locking gas cap, the only way would be that damn ethanol....
but the other vehicles are not affected, so go figger, but every once in a while their idle gets rough, then smooths out again, for some reason the vette acts much worse....but even it will smooth out a bit too....it's in the gasoline, beleive me, I would drain the tank, curious to know what you find when you pour that last gallon or so into a clear glass, I bet it looks like watered down coffee with milk in it....and smell like *** too....surely don't smell gas, smells like ***....
OP, if you do this, please PM me with what you find, highly curious, as it's been a bug for a long time now....don't want to miss any thread...
thanks...
Old Jan 3, 2010 | 05:43 PM
69VetteAngel
thanks...
You got it. I will let you know what I find. Hopefully, I will get to the bottom of this because I plan on removing the tank to look for my tank sticker. I actually have run the car pretty low on a few occassions because I don't drive it due to ongoing repairs. So I usually add a couple of gallons and that is used up pretty quickly just idling and moving the car around.
While it is out, I will flush it, and the lines. I'll replace whatever I have to based on what I find.
Thanks for the replies,
Greg.
Old Jan 3, 2010 | 05:47 PM
69VetteAngel
We are forced to run on 10% ethenol here. I have heard that it absorbs moisture and now that I think of it, the water would sink to the bottom (I think, correct me if I am wrong) and that may be why the corrosion is at the very bottom of the fuel bowl. If you look at aluminum rims, they corrode and pit after years due to oxidation and moisture. My rims have pits and corrosion just like the fuel bowl, so I think the guys are correct when they pin it on moisture contamination.
Greg.
Old Jan 3, 2010 | 06:04 PM
midyearvette's Avatar
midyearvette
can you look in the bottom of your tank?...i think what you have is a combo of rust and fuel causing a reaction or maybe dirt and fuel??
Old Jan 3, 2010 | 07:39 PM
81pilot's Avatar
81pilot
Ethanol
Old Jan 3, 2010 | 09:20 PM
20mercury's Avatar
20mercury
Default ethanol in gasoline
Outboard motor folks are really exercised about ethanol in the gasoline due to the effects described above. Outboard motor gas tanks breath in lots of moisture due to the nature of the usage and have less turnover in the gas tank. There are websites where you can find the local gasoline stations that still sell 100% gasoline. Check the marine sites if needed. I plan to start putting only 100% gas in the 76 and the boat asap. Ethanol containing gas will only go into the daily drivers for me.
Old Jan 3, 2010 | 09:43 PM
Thinpockets's Avatar
Thinpockets
The situation that I have, or had, is when I wash the car the drain around the fuel cap was plugged and the well would fill with water. When the car was put back in the garage and cooled, water would be theoretically drawn into the tank. Over a few months time that few ounces adds up. I should have replace the drain hose but instead I blew it out with an air gun. It now drains good but I haven't driven it much since. The stuff in your pictures look just like what I had only worse. My car is driven daily so the crap didn't have a chance to settle as much as yours.
Gas for all 4 of my cars comes from the same station.
Good luck
Old Jan 3, 2010 | 10:04 PM
lars's Avatar
lars
Your problem has nothing to do with ethanol, Stabil, moisture, or anything that the previous posters have suggested.
Holley had a bad batch of carbs with bad plating, which has caused the carbs to erode internally. They are honoring warranty on these carbs, and they will give you a new carb. Call the Holley tech line and let them know that you have one of the carbs with the internal errosion/corrosion problems and they will exchange your carb.
Ignore the suggestions by the previous posters - you have a bad carb - I've seen a bunch of them, and Holley is replacing them.
Lars
Old Jan 3, 2010 | 10:41 PM
Thinpockets
Lars
That is good to know Lars. If Holley is replacing carbs with internal plating problems I should have one coming.
The OP's photos show red corrosion - is there something inside a carb that oxidizes red.
Old Jan 3, 2010 | 11:42 PM
WhiteC3's Avatar
WhiteC3
Really then I know a few people with boats that should have carbs coming too!And one edlebrock for my next door neighbor for his Ford.
Old Jan 3, 2010 | 11:43 PM
69VetteAngel
Lars
Thanks for that monumental information, Lars. I will be contacting them tomorrow. Thanks a million.
Greg.
To carburetor internal corrosion - fuel?
Old Jan 4, 2010 | 06:36 PM
Rich's'78's Avatar
Rich's'78
Default rust
No. You have rust sediment. Forgret about ethanol. Sh*it in the tank or your distubributor.
Old Jan 4, 2010 | 06:47 PM
377's Avatar
377
I use sea foam its like stable but works 75% better it is used in boats for the winter.some people use it all year round.
Old Jan 4, 2010 | 09:03 PM
69VetteAngel
I was just holding a can of that at Autozone today, but put it down. I have to try it now as you are one of many that had mentioned it.
I called Holley tech today, and after giving them my list # and date codes, they told me that my carb was not in the batch of "bad Plating" that would cause this. They said it MUST be something in the tank that caused this. I will be draining the whole system and flushing it out.
Greg.,
