How do I remove washer tank?
Old Jan 4, 2010 | 10:51 PM
Bronze76's Avatar
Bronze76
Default How do I remove washer tank?
The windshield washer pump seems to have finally called it quits. I tried to remove the tank so I can service the pump but it looks like the master cylinder (and possibly booster) needs to be removed before the tank can come out. I did notice the neck of the tank comes off, so that seems to help but I still can't get the tank out of there.
Am I missing something here? There must be an easier way. At this point, any help is much appreciated (hopefully it's something really simple.....)
Old Jan 4, 2010 | 11:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'm not positive, but I think you can get to the tank by removing the lower splash shield. This is the shield that trim out the inner fender to the side rocker panel.
Willcox
Old Jan 5, 2010 | 12:32 AM
7T9Shark's Avatar
7T9Shark
You have to remove not only the lower splash shield, but if my memory of doing this is correct, the evaporator canister also has to come out.
Your better off keeping a bottle of Windex with you and give it a shpritz every now and then.
Cheers!
A.J.
Old Jan 5, 2010 | 07:50 AM
Aussie79's Avatar
Aussie79
I just fixed my 79, after spending many hours trying to work out how to remove it, the answer was simple. Give up and buy a $15 in-line pump, (any half decent motor parts store), remove the necks top screw, remove neck, it just slips out of tank, undo two bolts that hold the tank in place, a bit tricky here but not too bad, manipulate the tank until it is upside down or close to it, leave old pump motor in tank, cut hose about 2 inches from old pump, fit new pump in line, remove the two wire connector from old pump, remove copper connectors from the plastic housing and connect to new pumps pins, turn tank back up the right way and refit with two bolts, just let new pump hang, its quite safe in there, push neck back in and do up neck screw, fill with water and thats it.
Warning, tank and neck may be brittle with age so treat it like it is 30+ years old.
Cheers Dennis.
Old Jan 5, 2010 | 11:56 AM
Bronze76's Avatar
Bronze76
Thanks for the help. Sounds like a more involved job than is worth the results.
Dennis, interesting idea. Might give that a try.
Thanks again.
Old Jan 5, 2010 | 03:57 PM
marz's Avatar
marz
I just ten minutes ago removed mine. Remove the lower splash shield and then undo the three bolts holding the charcoal canister bracket and move it to one side. The washer bottle has three screws. Remove them and slide it out from underneath. Make sure to detach the electric clip from the motor itself on the bottle. I also have the one I removed for sale if someone wants it.
Old Jan 5, 2010 | 06:19 PM
cj77's Avatar
cj77
Got my 77 out thru the bottom. Worst part was forgetting how the the fluid lines were routed.
chuck
Old Jan 5, 2010 | 08:18 PM
RIO68's Avatar
RIO68
Willcox
Old Jan 6, 2010 | 09:24 PM
rbat's Avatar
rbat
anyone know where to get a new container, I tried ecklers, it is in the book but discontinued.
thanks
Old Jan 6, 2010 | 09:34 PM
marz's Avatar
marz
thanks
Maybe Corvette America ir Mid America. If you want mine just pay shipping and I will send it to you.
Old Jan 6, 2010 | 10:27 PM
0Willcox Corvette
Former Vendor
The 75-79 early jar is discontinued.. We might have a real nice used one. If you call sales 800-588-3883 and ask the to check.. someone will and call you back.
Willcox
To How do I remove washer tank?
