your timing gear phasing is correct....as far as your adjusting method, i am familiar of your approach but i do not use it....i prefer one at a time so i can watch the valve action but if you are sure of this method, it is certainly your choice (engine)..why the hurry?.....
Is the No. 1 cylinder at TDC compression after installing the timing chain with the dot on the cam sprocket at 6:00 and the dot on the crank sprocket at 12:00.
