Need some electrical help
Old Jan 5, 2010 | 09:20 PM
khubert035's Avatar
khubert035
Default Need some electrical help
I took my driver side dash off of my 68 convertible. On the bottom of the tach cluster is what I assume is a capacitor, only problem is the wire is missing. What is it for, and what does it attach to. Any help would be appreciated.
Old Jan 5, 2010 | 10:39 PM
1Fordman's Avatar
1Fordman
The capacitor was to reduce or eliminate electrical noises on the AM radio band. There should be a single 12 gauge brown wire that runs with the ignition switch wiring that plugs into the capacitor. There should be a plastic wire end cover over the end of the capacitor wire that mates with a plastic wire end cover on the 12 ga. brown wire.
