Big block conversion
Old Jan 6, 2010 | 07:05 PM
rbat's Avatar
rbat
Default Big block conversion
I am looking for info on converting my 75 th400 auto to a big block (zz454 or 502) and keep the ac if poss.
what am I in for and what do I need.
thanks
Old Jan 7, 2010 | 09:25 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Do a BB search. There should be a ton of threads over the years.
Old Jan 7, 2010 | 09:48 AM
midyearvette's Avatar
midyearvette
thanks
nothin' but $$$......the parts are readily available which is the REAL issue...
Old Jan 7, 2010 | 10:06 AM
Lester B's Avatar
Lester B
Lots of time patience and money....
I am in the process of fitting a 454 now.
Main things are:
Headers and larger exhaust
Uprated cooling system
New carb (and pos uprated fuel system)
New hood
New pulley set up
Also take into concideration plugs, leads, fluids, engine mounts, cam covers, gaskets, air filter, etc, etc. When you start you think you will reuse the SBC parts as they are 'ok'. When it comes to it and your fitting a new engine the urge to replace everything gets stronger and stronger.
Old Jan 7, 2010 | 10:48 AM
ajrothm's Avatar
ajrothm
Search here for my thread "The great rat transformation". Lots of pics info there.
You will end up replacing a lot more then you think you will. I did use my SB shroud, fan, radiator, alternator, PS pump. Pretty much everything else had to be changed. It ain't cheap, that's for sure...especially if you buy all new repro. Pullies, brackets etc etc. It is worth it when it's done though.
Old Jan 7, 2010 | 11:33 AM
Al Davis's Avatar
Al Davis
Default 383
Go 383 stroker, there is a lot of info on the internet. You can build a mild 383 from 350hp to a wild 500hp plus and anything in between! They also are capable of large torque numbers. There is also a large supply of crate motors and all the parts you will need.
Old Jan 7, 2010 | 12:31 PM
auavette's Avatar
auavette
I did change the sbc I had in my 76(TH350) to a blown 496(TH400).
Also changed the suspension to the monoleaf spring in front and back and changed the steering to a rack and pinion.
The a/c was a no no.
Powersteering is the pump attached to the block with a remote tank.
Pulley and belt is from March. Because of blower belt a dual electric fan was used as pusher and the radiator is from The Witts. One fan starts with the engine the other one kicks in at 185 degrees.
Old Jan 7, 2010 | 12:33 PM
damoroso's Avatar
damoroso
It's really not that hard, and it doesn't have to be crazy expensive either. I just did this in my 81. I used the original carb, and dizzy, built a 2004r (modified the stock shifter so I can reach 1st gear manually) for it and obviously true dual exhaust. I used an aluminum radiator with dual fans to keep it cool. I also adapted a stock sbc serpentine system to the bb so I could use all the factory accessories. I've just put the L88 hood on it, but haven't painted it yet, as there's some prep work to do and I haven't had time yet.
Pics are posted in "My Garage"
Old Jan 7, 2010 | 06:06 PM
rbat's Avatar
rbat
I was condidering a 383 but if difference is reasonable I really like the look of a big block. I have not experienced the feel but all the feedback is positive
I would be replacing the manifolds, carb, intake, fuel pump, fan shroud, intake manifold, air cleaner, distributor and converter (400 has been rebuilt) anyway for the 383.
Also, i have true SS dual exhaust (no cats) that I might have to modify...BUT really like the look of the side pipes so am considering that route.
not sure about my stock l88 hood and the cost of the pulleys and accessories.
I think the springs will be ok with all the cast of the sbc being replaced with aluminum.
I have been reading non stop (btw this is the best site) for the last two months, there is a lot of great threads but they go all over the place and there is usually a couple of things that are different that raise more question for me.
It would be great if there was a sticky on the subject
Old Jan 7, 2010 | 06:37 PM
eastltd's Avatar
eastltd
Big Blocks are Cool! Go fit It!
I love getting a chance to show off my motor
Old Jan 7, 2010 | 06:56 PM
rbat's Avatar
rbat
Default Niiiicceeee!!!
I can see why!!!!
Old Jan 8, 2010 | 09:29 AM
damoroso's Avatar
damoroso
Beautiful job!!! Gotta admit, I like showing mine too...especially the serpentine set up...
Okay I'm tired of being an idiot. How do you post pics like eastltd did?????
Old Jan 8, 2010 | 02:43 PM
rbat's Avatar
rbat
Default posting pics
go to FAQ at the top.....reading and posting messages....albums and pictures.....hope this helps....
Old Jan 8, 2010 | 04:42 PM
damoroso's Avatar
damoroso
Yeah, well....tried that. Used the "New Post" option, but the manage attachments button doesn't show. Also in the posting rules that shows up on my side, it says "You may not post attachments". Don't know why?
Old Jan 8, 2010 | 04:54 PM
rbat's Avatar
rbat
maybe you have to have a certain number of post first (higher member rating).
anybody have any other suggestions?
Old Jan 8, 2010 | 05:42 PM
eastltd's Avatar
eastltd
Open a Photobucket account and upload your pictures there first. Once you have them uploaded, copy & paste them into your forum post.
Old Jan 9, 2010 | 02:21 PM
damoroso's Avatar
damoroso
Okay, photobucket seems to be the answer, thanks!
To Big block conversion
Old Jan 9, 2010 | 05:37 PM
Aggitated Monkey's Avatar
Aggitated Monkey
Very nice install What did the serp come from?
Old Jan 9, 2010 | 05:43 PM
Stu's81's Avatar
Stu's81
That really fits up nice!!! How much does it stick out above hood?
I plan on using the stock Vortec fuel injection manifold and hoping it will be lower than a carb set-up?
Old Jan 9, 2010 | 06:22 PM
eastltd's Avatar
eastltd
Nice Motor!
I like the candy paint on the block. You don't see that everyday
