Performer RPM
Old Jan 8, 2010 | 04:38 PM
Al Davis's Avatar
Al Davis
Default Performer RPM intake
This should be my final combo. A 383 with a Lunati 60104 233/241 504/525 and I want to go with the Brodix Ik 200's. I know I will need to buy a Edelbrock Performer Rpm intake. My question is: Will the gas, trans kick down and cruise control cables hook up to my Qjet using the new RPM intake, as they do on my Performer now? Its a 79 Vette. What about my stock fuel line from the pump to the carb?
Old Jan 8, 2010 | 04:43 PM
Roughrider's Avatar
Roughrider
Edelbrock sells an adapter (as do other vendors) if you need one for your cables. You'll also need a drop base air cleaner as you won't have clearance for your stock unit with the underside of the hood.
Old Jan 8, 2010 | 05:15 PM
Ganey's Avatar
Ganey
Cables should fit & stock air cleaner will not clear hood.
Old Jan 8, 2010 | 07:09 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Yes!
__________________
1978 Corvette
406 SBC AFR heads Lunati roller Quadrajet TH-350 3.08
11.59 sec / 118.9 mph 1/4 mile
Old Jan 8, 2010 | 08:59 PM
SteveG75's Avatar
SteveG75
If keeping the Q-Jet, get the Performer RPM Q-Jet 7104. Everything bolts on just fine. Only issue is no provision for the hot air choke so convert the carb to an electric choke. If you use a dropped base aircleaner (my favorite is the Moroso Low Profile Racing air cleaner), you can fit a 3" filter under the stock hood. Only mod is massaging the filter base a little for clearance for the accelerator pump arm. You can see where I laid a long socket under the base and gave it a few taps.
Old Jan 9, 2010 | 08:02 PM
Al Davis's Avatar
Al Davis
Since all the gas, trans and cruise hook up okay, what about the factory fuel line?
Old Jan 9, 2010 | 08:16 PM
SteveG75's Avatar
SteveG75
Carb ends up about 1" taller than stock (hence the drop base aircleaner). Stock fuel line won't fit. I made my own stock style line using Lars' instructions.
To Performer RPM
