I currently have a TH-400 in my car and I am considering changing to a manual and my question is this.
My 383 is externally balanced, what type flywheel do I use to keep everything balanced ?
Get one that is for an externally balanced motor. Your 400 used the larger flywheel so your starter is set for the larger 168 tooth flywheel. There are plenty of flywheels out there take your pick.
Thanks Gordonm, so any external, 400, or big block flywheel will work ? This is the first externally balanced engine I have ever messed with and was a little confused.
If you or anyone else is interested I have a 168t GM flywheel casting #3973457 it`s in good condition and I believe it`s from a 454 w/2piece rear main...send a PM if interested
The only BB that was external was the 454 so it would have to be from a 454.
