TPI Conversion query....what HAVE I done?
http://forums.corvetteforum.com/c3-t...l-started.html
I have a modified harness that allowed me to put the computer behind the seats. It runs down the pass side tunnel with some speaker wires(disregard the Pioneer amp under the pass seat, I was just sitting on it!):
The trunk of the harness runs through the old HVAC/AC wiring grommet and sits up against the firewall just about exactly as it looks in the next picture. It fits under the heater box pefectly and just clears the vert's metal trans tunnel bracing. The AC/HVAC wiring now utilizes the vacuum line grommet visible just to the left of the TPI harness in this pic:
These are the lines coming out on the engine side of the firewall:
But MY swap is being done because I want the rebuilt engine, EFI is so much smoother and more reliable, easier to start in cold weather...plus, it looks sweet under the hood.......AND for $250 I couldn't really say no!
But.........I did run the vin on the donor, and ran into a small "snag" I guess you could say. The kid that I bought the car from said that it's a rebuilt 350 motor, but the vin decodes as a 305! I have not pulled the numbers on the block yet, but I'm hoping that it's NOT a 305 motor. I had bought the whole setup with the thought in the back of my mind that I could just always pull the TPI stuff off and swap it over to the 74 block that I have, but of course that requires swapping heads, distributor, and such. Plus I would need to see if all of the accessories that came with the motor would change over....OH, and let's not forget a 350 ECM prom. So I was little discouraged when I saw that...and never really thought to check that before I bought the engine. It's not too big of a deal, but still not what I was sold.
I know some of the C3's came with a 305 out of California....but my question is this. The car that it's going in is my wife's car...so absolute raw HP is not that big of an issue. I know the 305 would have plenty of scoot to it, maybe so my wife wouldn't get in as much trouble!!! Is the 305 going to be a dog in there? I mean, the 185 stock horse in a Vette 350 seems about the same. Maybe it would be a slight improvement in HP, I dunno. I've got a 305 TBI in my 89 Chevy truck, and it's not the fastest truck on the planet. I'm just needing some moral support and/or input on this one here guys. Feel free to chime in.
Maybe the older 350 block with the TPI goodies swapped over, plus a set of cheap vortec heads would fit the bill??
FIRST you have to check whether the engine you bought is a 305. If it is, then the seller has probably lied about other things, such as "only 11,000 miles on the engine".
If it is a 305, its not going to be any sort of performance engine because of the 305 heads. You will be better off with the '74 or whatever other 350 engine you have. You can install all of the TPI parts on it (you may have to drill the center bolts on the TPI manifold to match the angle of the mounting bolts on your heads) You will need a different knock sensor and a different chip, which are specific to the 350. Neither is very expensive. You may also need a set of 22 to 24# injectors unless you try to raise the fuel pressure to 48-52 lbs to give it the fuel it needs through 19# injectors. The 22 to 24 # are not too expensive off of ebay (If interested, I have a good set of 24# Ford/Bosch blue tops for $75).
You cannot use vortec heads with TPI unless you get a new manifold from Scroggins-Dickey or Edelbrock. This will cost approx $450.
Keep us informed.
I was going to leave the transmission in the car and just use the stock TH350, but after thinking about it longer I decided to go with the 700R4 in order to get the overdrive, and I will not have to fool around with a VSS conversion. I'll still need to sort out the whole speedometer cable issue, since the new trans does not have one, so I guess I may still have to get some sort of an adapter for it. Not a biggie.
PLUS....and here is the really good news....the block IS a 350!! It says right on the back of the engine "5.7"!! I was beginning to get a little bummed out, thinking that it was a 5.0, but I don't have to worry about that now. I will need to make sure that I have the right prom in the ECM, as I do not know if the kids changed that over. He SHOULD have, but that doesn't mean he did. I'm sure it would not have run right if he didn't, and who knows, that might be IN PART why he parked it after he blew the rear end out of it. I will be checking all of that, you can be sure of that.
Overall, then engine looks to be in good shape, with the exception of dirt and grease on the sides of the block. I think he may have forgotten to put valve cover gaskets on there! And for some odd reason......the water pump is orange. ?? I guess he couldn't spring for the can of black paint....the water pump from another engine was all that he had....or he really liked an orange water pump on there. Any which way you look at it, it needs a new water pump!!
But I am a happy camper tonight, and I got the whole setup wheeled into the garage, wires, transmission and all. PS....before I pulled the motor out of my Vette, 2 weekends ago, I had never pulled a motor EVER. Plus, I did that by myself, and I got the engine and trans out of the donor by myself! I'm pretty proud of myself, if I do say so....myself!
A lot of "firsts" for me here, and I'm just diving in with both feet. So if there are any other first-timers that are thinking of doing stuff like this but are too afraid....DON'T be. If I can do it, ANYONE can do it. Just get your feet wet, and don't be afraid to make mistakes.
Oh...and is there a crossmember that will bolt in to hold the 700R4, or will I need to fabricate that (Lord I hope not).
Also, I would seriously consider buying one of the reprogrammable chip-replacement options rather than just getting one burned. You'll spend a little more up front, but if you decide to mod the engine at all, you'll spend less money than you would getting two custom chips burned.
Good luck!
Good luck!
I've been curious about how to add the SES light into the dash setup on the 76 as well. Just a little hazy on the finer details needed for this swap....but I sure know a HECK of a lot more than I did when I set out on this quest less than 2 weeks ago!! Thanks in advance!!
Trevor
one thing I think you want to do, something I just did as a possible cure for some gremlin that showed very recently, I ran a 10 ga wire from the engine to the metal of the body, directly, and in the wiring, I grounded all the computer grounds to the engine directly....injectors are grounded to engine block directly at the engine....
And what do you do with the diagnostic port? Does this come off easily, and is it connected directly to the ECM? I poked my head under the dash, right before it started pouring rain tonight, and it looks like it gets tied in with the dash wiring harness. Am I missing something?? And I DO already have HEI as well.
The manual IS good, don't get me wrong, but I need specifics on WHAT needs to be hooked up...HOW it's hooked up....etc. Hopefully when the service manual for the donor car arrives it will tell me more.
Also, I hooked the SES light wire to the seat belt warning bulb in my dash. I took off the OBD-I dash connector and hard wired a USB ALDL cable so I can monitor the engine with my laptop (I use TunerPro).
First, this is the engine that was pulled out. As you can see, it's clearly not a Corvette engine, based on the brackets and exhaust manifolds. It all fit in the engine bay alright, but you spot the bracket setup right off.
And here's the new one.....please excuse the greasy mess on the side of the block and the clutter in the background!
A little messing around on the runners shows that they should polish up nicely...after the dents are removed. Doh!
http://forums.corvetteforum.com/c3-g...o-my-73-a.html
