vacuum advance cold start experiment
Old Jan 11, 2010 | 01:33 PM
Matt Gruber's Avatar
Matt Gruber
Default vacuum advance cold start experiment
coldest in 20years here. house gets so cold, i might as well dress warm and go in the garage in the AM.
so after doing some research i dreamed up this experiment:
under dash "hold" valve for vac adv.
chrysler data says that cold, it needs more advance.
some cars like mine have weak vacuum on a cold start (no choke) so it gets less advance when it needs more. stalls.
if this cold was normal, i'd get a choke; but as a hobby idea, i'm going to try turning the valve "off" at 1500 when vac is high. then when i let up, it will maintain full vac adv even if vac goes real low.
the chrysler data also says it needs more adv even accelerating cold and will run soother and get more mpg advanced. so, what the heck, i'll try that too. Very crude test, but i'd like to see how it runs. Once it warms up, i'll open valve and vac adv will work normally.
EDIT: i'm just going to loop a long vacuum hose under the dash and clamp it on start up for the test.
Old Jan 12, 2010 | 01:47 PM
Matt Gruber
Default WORKS! Kudos to the Chrysler engineers!
Only took 1/2 hr to hook it up.
Started it, clamped hose w/18" vacuum, took 10 seconds to lock the advance on FULL. Drove out, no warmup.
It liked the extra advance lots! Ran like it does in the summer, despite the cold and no choke.
Too bad the 1976 "lean burn"(falsely named) was a failure, they used primitive electronics; i used some hose and a clamp
EDIT
this isn't all choke related. What happens when i pull out from a dead stop cold, it takes more throttle, and briefly, vac drops enough that the vac adv drops out, then it bogs, and i have to pump it or it will stall.
SO NOW,
advance does NOT drop out, it doesn't BOG, and it pulls out normally.
Old Jan 14, 2010 | 10:30 AM
Matt Gruber
Default please read link
see Bill Jones posts:
29.9 mpg with carb!
uses TVS Trapped Vacuum Spark, similar to my test.
http://speedtalk.com/forum/viewtopic.php?t=2178
site loads FAST even w/dial up.
Old Jan 14, 2010 | 11:06 AM
Rich's'78's Avatar
Rich's'78
My '85 pontiac had a TVS-controlled vac adv lock-in with a "distributor vacuum delay valve" for the first part of warm up (went to normal vac adv at 100*F). It let it run leaner on the choke.
Old Jan 14, 2010 | 12:57 PM
lars's Avatar
lars
Model T Fords have a similar system: A lever on the steering column for the driver to adjust the timing as needed... Driving a Model T, you crank in more timing when cold and back it off when hot or under load.
Old Jan 14, 2010 | 08:21 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
An adjustable timing control is what you need. These are no longer available from msd but come up once in a while on Ebay. They have one for an MSD box too.
http://cgi.ebay.com/ebaymotors/ws/eB...y=33691&ih=014
Old Jan 15, 2010 | 06:01 AM
Matt Gruber
good tip!
crane made 1 too.
J&S has a knock retard system.
To vacuum advance cold start experiment
